| | #1 |
| Zilvia Member ![]() Join Date: Jan 2012 Location: willow springs california
Trader Rating: (1) Feedback Score: 1 reviews | Im asking for a rundown, im about to pick up a car this weekend, I will try to give as much information as possible. Its a 1991 240sx hatch no sunroof or power options, the motor is a rb20 that has been overhauled it was originally dual cam according to the owner, he said he purchased a lower swap harness from a company and the upper harness came with the car, but the problems that I know of are Check engine light wont light up No tach signal at all No coolant temp signal Speedometer works Fuel gauge works gauges are illuminated Any help would be appriciated
__________________ I would drive it like I stole it, but even then I would be more careful |
| Sponsored Links | |
| | #2 |
| Leaky Injector ![]() Join Date: Jun 2012 Location: newport mn. Age: 29
Trader Rating: (0) Feedback Score: 0 reviews | You should find this to be helpful. After you get the car. I might be able to walk you through diagnosing it better RB20DET Wiring Guide For Dummies |
| | #3 |
Trader Rating: (1) Feedback Score: 1 reviews | I am also curious to how difficult this could turn out to be, worst case scenerio? Im not bad with wiring just not so happy I might have to do it
| | #6 |
Trader Rating: (1) Feedback Score: 1 reviews | No the car runs, drives,boosts perfectly, the speedometer gas gauge and light also work just the problems listed above
| | #8 |
Trader Rating: (1) Feedback Score: 1 reviews | Then im going for it, thanks for the help I will definetly take you up on the offer to walk me through the wiring if I get stuck Sent from my front right pocket,damn its dark...
| | #10 |
Trader Rating: (1) Feedback Score: 1 reviews | Can I access all of the wries easily or must the cluster or dash be pulled out
| | #11 |
| Zilvia Junkie ![]() Join Date: Feb 2009 Location: Allentown, PA Age: 27
Trader Rating: (0) Feedback Score: 0 reviews | it's pretty easy. it's in the kick panel where the computer is. if all else fails just wire up an aftermarket 5" tach and the coolant might just be a bad sensor. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
