Old 07-01-2012, 11:54 PM   #1
KA24DE wont idle! PLEASE HELP
Ok so i had to rebuild the top end of my KA pretty much. swapped the transmission to a five speed and am running the auto ECU because i was under the impression it would be fine that way. got it all back togther now and it starts and jumps to about 1500-2000 rpm then dies but if i give it gas it will keep running and runs well in the top end. But if i uplug the MAF and start it it will hold at 2000 rpms steady and runs relatively well. i've checked all MAF wires and they are fine cleaned and tested iacv and check for vacum leaks with the hookah smoke smoke test (totally worked found two like that). ive place at TDC and set the rotor plenty of times lobes on cams are perfect. ive swapped ecu, wires, mafs the #4 injector checked all the injector gaskets. EGR has been deleted also. I pulled the plugs and apparently its super rich they are wet with gas. IM AT A LOSS! any help would be greatly appreciated haha i swear my car hates people
TATE843 is offline   Reply With Quote
Old 07-02-2012, 01:12 PM   #2
really need help guys i need my car to work
Old 07-02-2012, 01:18 PM   #3
now its smoking out of the exhaust a good bit and smells like fuel so its either mis-firing or running super rich and still wont idle
Old 07-04-2012, 11:49 PM   #4
PLEASE HELP i need to get this shit working its a capital asset
Old 07-05-2012, 12:47 PM   #5
Check the injector o rings see if they arent leaking? That will cause engine to ru extremely rich
ka4life87 is offline   Reply With Quote
Old 07-06-2012, 12:04 AM   #6
R.I.P. David Mudge
zerodameaon's Avatar
Check TPS.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
SEO by vBSEO 3.6.0 PL2
