| | #1 |
| Zilvia Member ![]() Join Date: Nov 2011 Location: Buckeye AZ Age: 29
Trader Rating: (7) Feedback Score: 7 reviews | Question about rb20det into s13 wiring Ok so I'm splicing in the grey oval plug to the rb harness I can't figure out where the black and white wire goes (ecu power) I wired the red one which is ecu constant power so do not use this wire? And also off the oval plug there's a ground do I just ground it to the chassis or what? Thanks for your input I've searched and searched came up with nothing |
| Sponsored Links | |
| | #2 |
| Zilvia Junkie ![]() | |
| | #4 |
| Zilvia Junkie ![]() | I would wire without and see what happens. I used that diagram and another when wiring. If you are still having problems come Monday update this thread and I will check out my wiring. Be sure to wire the resistor for the alternator |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
