Old 04-21-2012, 06:20 PM   #1
RB rb20(det) swapped 240sx struggles to start, when running struggles to idle then dies.
It struggles to start up and when it does it has wwhite smoke coming out (open dump/exhaust) smells almost sweet. You gotta give it throttle to keeep it alive and it runs poopy anad just dies. When it was running decent it still didn't wanna idle. I have cleaned the maf and replaced the plugs and adjusted the cas. I really need advice as this is my daily driver and have been stuck the past week.
mixedkid240sx is offline   Reply With Quote
Old 05-29-2012, 07:16 PM   #2
chubz7793's Avatar
check your idle
control valve
chubz7793 is offline   Reply With Quote
Old 06-17-2012, 09:11 PM   #3
I found Out that motor was junk. I have since replaced the motor with a new rb20. Everything is wired up correctly and all grounds are hooked up. Put has in it and still won't start. Brand new plugs and good coil packs. Turns over all day long and when we put a little bit of gas in the intake manifold it started right up. I don't think it's getting fuel to the injectors.
Old 06-19-2012, 08:05 AM   #4
sounds to me like your burning coolant. most likely shot head gasket or cracked block. check to see if you oil is milky looking and also take the cap off your radiator and see if there's combustion gas bubbling up in there.
se-real is offline   Reply With Quote
Old 06-19-2012, 02:01 PM   #5
It's a brand new motor with a guarnteed startup. It ended up being a fuse that my buddy overlooked. She is idling perfect and running good. We haven't bled the clutch yet and I took it for a drive and down low the clutch works and it will go but if you try to give it more gas it just revs. I think it is just slipping really bad. So I guess I'm Gunna be ordering a new one.
Old 06-21-2012, 08:56 PM   #6
what fuse was it? cuz that seems weird that a fuse would do that...
Old 06-21-2012, 09:43 PM   #7
It was the fuel pump fuse. That was why it wouldn't start.
Old 06-24-2012, 10:04 AM   #8
burning coolant is the only thing that will do that from what i know. just sayin
Old 06-24-2012, 10:26 AM   #9
That watches old motor. The new motor is running perfect and the new clutch has been installed. It just needs bled now.
SEO by vBSEO 3.6.0 PL2
