| | #1 |
| RB25det NEO 6 REV PROBLEM I been having problems with the idle on my rb25det neo 6. i would start the car and the idle would be at 4rpm soo I adjusted the TPS sensor and my idle is normal. but when i try to drive the car. i can reach about 20mph in 1st gear but when i shift to second gear the gas pedal does not work anymore the engine gives out the idle drops to 1rpm i can press the gas pedal to the floor and nothing will happen. . When i drive in first gear after about 3.5rpm the gas pedal does not work anymore the car just gives out and jerks then comes back to life again after the rpm drops below 3. We checked everything and we cannot find the solution. The one thing is im using a rb25det MAF. should i be using a rb25det NEO 6 MAF? all the wiring and everything is done correct. the engine revs perfectly fine when its not in gear. | |
| Sponsored Links | |
| | #2 |
| Premium Member ![]() | What color is the sticker? Green? If so then that is an RB20/25 Series 1 MAFS (J60) you need the R34 NEO MAFS. Neo MAFS are Pink Tagged E61's
__________________ 1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress Don't Buy Engines from JDM-Online http://zilvia.net/f/businesses/207457-jdm-online.html Don't Buy XS-Power or SSAC Shit http://zilvia.net/f/chat/332057-project-rb-how.html (Half Way down) |
| | #4 |
| Premium Member ![]() | Either an SAFC OR I actually have an RB25 NEO MAFS that was given to me in my Engine Set Incorrectly, Ive been trying to find a Green Sticker J60 MAFS. Wanna Trade??? EDIT: How did you wire up the Green tagged MAFS? The plugs are different.
| | #6 |
| Premium Member ![]() | PM Sent Msglnght
| | #10 |
| Premium Member ![]() | MAF might be dirty, Clean it with CRC MAFS Cleaner and see if that helps. Or break open the FSM and test it accordingly
| Bookmarks |
| Tags |
| rb25det, skyline |
| Thread Tools | |
| Display Modes | |
LinkBacks (?)
LinkBack to this Thread: http://zilvia.net/f/engine-tech/331976-rb25det-neo-6-rev-problem.html | ||||
| Posted By | For | Type | Date | Hits |
| RB25 | This thread | Refback | 07-16-2010 08:10 PM | 5 |
