Old 11-12-2009, 05:52 PM   #1
fcdrifter20's Avatar
Need help asap
ok guys i got a big problem..... i got no spark... i have power to the cas plug, i have a knone working ignitor,switched coil packs with knone working one, all my grounds have been tripple checked so has my wiring at the chasis plugs. i have power at the ecu at to each coil pack output, so does each ecu pin for the cas sensors, 180 degree, and 1 degree. eccs power and back up power are all good. but i still have no spark. tore apart coil pack harness and it at looks good.
is thr anything else i could be missing to check????wut should my reading be after the cas? and how do i check that i dont kno wut it could be??when i move the cas by hand and the ignition on, i should i hear injectors click??? maybe harness???but if im getting power to all those things then my harness should be good rite???
im thinkin cas, but i dont have anothr one to pull and use at the moment.
fcdrifter20 is online now   Reply With Quote
Old 11-12-2009, 07:44 PM   #2
SleepR 240sx's Avatar
Send a message via AIM to SleepR 240sx Send a message via MSN to SleepR 240sx
Pull codes. Pull codes. Pull codes. Pull codes.
This is zilvia. We aren't nice.
Quoted For Truth
SleepR 240sx is offline   Reply With Quote
Old 11-12-2009, 10:11 PM   #3
that wont work. since engine wont start ecu wont pick up the malfuncion. but i did try that at first and im getting all good code 55
but i have an update. i have no power to the coil pack harness. ima try running direct power to that tomorow when i have some light, and see how that works. but i would still like input from anyone who has had similar problems. thnx
Old 11-13-2009, 06:41 PM   #4
problem solved can a mod plz close the thread
SEO by vBSEO 3.3.0
