| | #1 |
| Zilvia Member ![]() | KADE-T Stalling problem help!!!! Ok, i have a 1991 240sx Ka-t. I am trying to figure out why my car is stalling when comming to a sudden stop. Whenever I am in high speed or car is reving high it stalls out when I slow the car down to a stop.. whats causing this? The car doesnt stall when i am driving on low RPMs or when i am driving in a slow speed. Sometimes when i noe the car is going to stall out when i slow down i give it gass to save it.. Im thinking IACV? TPS? Any advice will be appreciated!!!! |
| Sponsored Links | |
| | #3 |
| Zilvia Addict ![]() | Mine did that just before it blew ![]() nah I'm j/k but check your timing. What's your setup? Your mix could be a little too lean I've had that happen to me. I fixed mine with timing adjustment and S-AFC2.
__________________ |
| | #5 |
| Zilvia Member ![]() | my MAF is good, been checked already.. my setup is 550cc SAFC2 Enthalpy Tuned ECU Stock timing, havent mingle with timing since turboed Dont think i have a boost leak, check for that a while ago, but it wont hurt to double check. I will try disconnecting the bov and caping the vacuum line. Any more suggestions? |
| | #7 |
| The Nismo Shop ![]() | your fuel might also be running too rich, have you tried leaning it out abit or is it already tuned specifically for your setup?
__________________ ![]() http://www.thenismoshop.com http://www.prettys13.com http://www.lugnutmotorsports.com |
| | #9 |
| Zilvia Member ![]() | Recirulate your BOV. The SAFC is measuring air that is not there anymore. When you come off boost and it blows the air through the BOV it causes a rich condtion quickly and stalls the engine. You can tune this out throught the SAFC on the decel air menu but i don;t know how. |
| | #11 |
| Zilvia Member ![]() | well i have a tuned ecu with my setup, and i can run my tune ecu without my safc2 and it will run fine, so i dont think adjusting the safc will have anything to do with it. And yes my wideband read 14_on idle which is pretty good. I have took all the emission stuff off and block the EGR with a block off plate |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
