Old 11-09-2009, 05:37 PM   #1
ka24de motor sputtering!!!
my ka is sputtering at high rpms in all gears. feels like fuel cut but its bone stock. some one told me distributor but others said no. can some one lead me in the right direction?!?!
jaebo is offline   Reply With Quote
Old 11-09-2009, 06:21 PM   #2
sounds like your fuel pump is about to give out. change it out youll be good.
sidewaysonmy180 is offline   Reply With Quote
Old 11-10-2009, 10:16 AM   #3
FRoSt415's Avatar
Send a message via AIM to FRoSt415
could be lots of things honestly. have you floored the gas pedal and it sputters or cuts off while reaching wide open throttle??when the last time it had a tune up? check fuel pump ,don't just replace something before u make sure it works or doesn't work. ran out of gas recently?
FRoSt415 is offline   Reply With Quote
Old 11-10-2009, 10:21 AM   #4
chetacheese's Avatar
Send a message via AIM to chetacheese
fuel injectors. does it feel like you have a loss of power? if so, check the o-rings. you can also listen to the injectors themselves while the car is running and listen for a repetition of ticks.
chetacheese is online now   Reply With Quote
Old 11-12-2009, 11:30 AM   #5
yea it cuts off when i floor it. but it smells like its just dumping fuel n not burning up.. as if its not getting enough spark but i changed all the ignition parts.. i read that it could be my ecu codes? maybe??
Old 11-21-2009, 09:24 PM   #6
Similar problem
I am having a similar problem. I replaced Distributor cap, rotor, spark plugs, and cables. I turn the key, it tries to start but doesn't. The starter is good, and the battery is new. I've been reading and it sounds like it may be the fuel pump. Does anyone have any suggestions? Or does anyone know where I can find instructions on how to change it out?
F1Luis is offline   Reply With Quote
Old 11-21-2009, 09:29 PM   #7
udon!'s Avatar
could it be the fuel filter?
udon! is offline   Reply With Quote
Old 11-21-2009, 09:32 PM   #8
SleepR 240sx's Avatar
Send a message via AIM to SleepR 240sx Send a message via MSN to SleepR 240sx
Vaccuum leak anyone? Always check the obvious stuff first. Check your vaccuum lines/battery ground before you replace anything.
This is zilvia. We aren't nice.
Quoted For Truth
SleepR 240sx is offline   Reply With Quote
Old 11-21-2009, 09:33 PM   #9
How do I check? And do you know where I can get instructions or directions on doing it myself? I A few weeks ago, the engine starting shaking pretty bad, after putting a bottle of Lucas injector cleaner it fixed things. Then I completely forgot about it and never addressed it.
Old 11-21-2009, 10:00 PM   #10
s142jzkillav10's Avatar
Send a message via MSN to s142jzkillav10 Send a message via Yahoo to s142jzkillav10
One thing We all over looks is Timing, MAF,and if that is good it's a Posibility it's your KNOCK SENSOR.
s142jzkillav10 is offline   Reply With Quote
Old 11-21-2009, 11:13 PM   #11
What about the injector cleaner fixing the shaking that made my car sound like a REX lol?! Any suggestions help. How do I check my fuel filter?
Old 11-21-2009, 11:21 PM   #12
I have been having the same exact problem for a few weeks now, I changed the fuel filter, spark plugs (they were fouled) and the distributor rotor (it was totally fried), it still sputters a little, it is getting progressivly worse, it has no vaccuum leaks, a new battery, new plug wires too...... I did a compression test and it passed with flying colors... any answer to this would be fantastic.. I am leaning towards fuel pump.. any way to test that to know for sure?
MikesS13_1989 is offline   Reply With Quote
Old 11-21-2009, 11:37 PM   #13
I am going to replace my fuel filter tomorrow. I hope that fixes it. Does anybody know where I can find a video on how to replace the fuel filter, fuel pump, and injectors on a kA?
Old 11-27-2009, 04:40 PM   #14
i found it my gas tank was rusting out n totally stopped up my whole fuel system strainer filter lines etc. suposebly if you let these cars sit for a good amount of time it happens pretty easily..
SEO by vBSEO 3.3.0
