| | #1 |
| Leaky Injector ![]() | SR20 help! Won't start! Here's my old thread: SR20DET bogs and dies Got a new fuel pump today and my car died and wouldn't start just as I pulled into my driveway. Ok, great. Well, at least I'm at home and I have the part I need. Out with the old pump and in with the new. Still won't start. Cranks but won't turn over. I got lucky a couple times and it fired up and seemed to be fine.. then it died 3 seconds later. Any suggestions? |
| Sponsored Links | |
| | #2 |
| Leaky Injector ![]() | ECU's throwing a code 55: 55 - Other Malfunction. CONSULT Terminal Required I can get it running now by flooring the accelerator pedal while starting it, but like before, it dies after 5-10 seconds now. |
| | #3 |
| Premium Member ![]() | fuel filter? bad injectors, i wanna say backwards fuel lines but when i did that mine wouldnt even start (fuel lines backwards, return line comes off the regulator)
__________________ 1995 240sx SE (current) |
| | #4 |
| Leaky Injector ![]() | Think the cylinders got flooded somehow cuz it only fired up when I floored the gas while starting it. Either way.. I started it again now by doing that and it didn't die! Hurrah! Seems to run fine now so maybe the excess fuel got burnt and/or dried? |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
