Old 11-03-2009, 03:20 PM   #1
Send a message via Yahoo to wannaB!
is it my MAF????
so last year i bought a 96 euro spec S14 from a guy who was getting a divorce, and getting out of the military, i got a pretty good price on it. the euro spec s14's come stock with the SR20DET in them, he had a few mods done...the valve train is pretty built; BC stage2 cams, titanium valve springs and retainers, aftermarket headgasket, and rocker arm stoppers. there was also a Z32 MAF installed on the car.
now that i am done with school for a while i would like to dedicate some time to her and get her ready for the spring... the problem is, when she sits at idle, it purrs like a kitten, but when i take her over 5k rpms, the idle starts going all over the place and she eventually stalls. then it will not even idle right after that.
to run the Z32 MAF, does you ecu need to be chipped???? i have check all of the fuel lines and even cleaned the injectors, so what i came up with was the MAF. how can you tell when one goes bad???
thanks for your time,
mike
wannaB! is offline   Reply With Quote
Old 11-04-2009, 01:12 PM   #2
well since your going faster the car offcourse needs more air but it aint getting enough, check the air fuel ratio, im sure its the maf. Its always the maf!
jdm213 is offline   Reply With Quote
Old 11-07-2009, 02:10 AM   #3
thanks for the feedback man. i will be ordering a new Z32MAF and pigtail from enjuku next week!
Old 11-07-2009, 02:14 AM   #4
SoguRacing's Avatar
Send a message via AIM to SoguRacing
no man. dont just order a maf. they're several hundred dollars. check for boost/vacuum leaks of the sort and check for the output voltage of the maf.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 11-07-2009, 02:27 AM   #5
checked for the boost and vacuum leaks, there were none. what should the voltage on the maf read?
Old 11-07-2009, 02:34 AM   #6
Killa_D's Avatar
your ecu needs to be chipped/tuned for it to use a z32 maf.
Killa_D is online now   Reply With Quote
Old 11-08-2009, 12:26 PM   #7
I thought so! thanks man!
SEO by vBSEO 3.3.0
