| | #4 |
| Leaky Injector | |
| | #6 |
| Leaky Injector | there is one SR20DE that i found with ITBs. Super Street featured it. here is the link. but you cant really get too much information from it. 1991 Nissan 240SX N/A - Import Cars featured - Super Street Magazine |
| | #8 |
| Premium Member ![]() | Itb's will rob power low end and give you some power top end. Hence why you see them mostly on motorcycles and such. Also without a crazy ECU setup you will have constant tuning issues. |
| | #9 |
| Leaky Injector ![]() | You don't need anything crazy, just a map based ECU (like pretty much any standalone..).. I think it's possible to make over 200whp with a built N/A KA.. All you need is high compression(12-13:1), well designed exhaust headers, head work (cam's, valves, port and polish, etc..), race gas, and advance the timing like crazy... But I still don't understand why people want N/A if they are looking to make power.. |
| | #10 |
| Leaky Injector | yeah. i imagine that ITBs of course dont make as much flat out power compared to boost. im looking into this because i strive to be different. although "difference" may cost more in the long run and cause more initial problems. but im trying to do as much research and find the easiest way possible to create a project. |
| | #11 | |
| Can speak French....in Russian ![]() | get the Tomei ITB's and their Reytec ECU and call it a day. ITB's are not for big power, they are for throttle response and helping the power band on NA be more linear. Although they can be an important step to making big(er) NA power. It also controls the flow, direction, and amount of turbulence of air going into the cylinders on the intake stroke of the engine. Just a reminder that the more air that can be stuffed into cylinder, the more power you make (along with the accommodating fuel ratio). yes thats all laymans terms this might help with theory, yes its a honda site Individual Throttle Bodies - Kinsler Reinvention - Honda Tuning Magazine
__________________ The Beatings Will continue.... Until Morale Improves Quote:
S.P.P.S. Member #00**CoUpe LOve** Member #00 | |
| | #13 | |
| Can speak French....in Russian ![]() | not sure how you plan on comparing KA SR to 4AG what are the relevant features you would be looking for? I mean your saying you would like to be competitive against one?
| | #15 |
| Zilvia Junkie ![]() | it all comes down to what u wana do and how far your willing to go..i have a ka,built/balanced bottom end wit 11.0.1 c/r on my n/a set up with mild head work,no cams or spring kit yet(will have by the time i get out of school) wit a tuned ecu from efi specialist n im luvin it so far bro.waay more responce n power difference from jump...i dont see y more people wont build n/a set on ka's,with agood turbo set up pushin more than 300hp your gonna spend a good amount of money ..you'll spend not even as much on a nice n/a build with forged internals |
| Sponsored Links | |
| | #16 |
| Leaky Injector | well, in comparison to the 4AGE... i would like to have all the capabilities it has while maintaining a naturally aspirated KA or SR. i mean, i've seen it done, so im not far off. im just trying to gain more information from the experienced rather than me having to read every thread and goggle everything. |
| | #17 | |
| Can speak French....in Russian ![]() | I understand where your coming from on that point but reading and reasearching for yourself is always going to net you the best results. By doin your own research you dont get the biased opinions of hundreds of dumbasse on a forum. Yes you might get some of the info you are looking for but you will never get just straight facts, someone will always be adding their two cents and what not. That said....... figure out these things first. 1) Power (whats your goal?) 2) Budget 3) And fabrication, do you have the skills and tools to reach your goal or you going to have to pay someone for their time? once you figure those general things out youll have a better idea of what it will take to reach your goal. You just have to think responsibly and dont try and do huge things all at once, go step by step and make sure everything is done right the first time. other than that its not hard at all to build a KA/NA SR to compete with a 4AG, just because your starting with bigger displacement. For a KA try to reduce the rotational mass causing parasitic drag. For a SR try doing head work and changing pistons do bump up compression. also go look at these. They will give you more Ideas than you will ever be able to use. Project Low-Buck SR20DE - Garage Tech - Turbo Magazine Nissan 240SX KA24DE Buildup - Turbo Magazine
| | #18 |
| Zilvia Junkie ![]() | good points..ka cranks if stock rebalance them it will take a good amount of wieght off or go a lil further n knife edge it n polish it..if you have the money bc makes a stock displacement fully countered crank(billet) for i believe 1700(its cheaper if u get a group buy though.ka head flow real well but u can always improve |
| | #19 |
| Leaky Injector | my power goal is at least a good reliable 250whp NA. im not trying to build everything off the bat. obviously thats financially impossible for me. but can be done over time. but still my budget is not unlimited. so streetable power that can be abused when i ask it too. |
| | #20 | |
| Quote:
| | #22 | |
| Zilvia Member ![]() | Quote:
LOL, be prepared to spend alot of money and still not reaching that goal, look up Greasers Itb Ka project, he is making around 235whp or so with his KA Itb setup but there is alot of R&d in that project and that motor has been pretty much redone from bottom to top, the head has been fully ported and polished and hes running a standalone, also that setup is nowhere near streetable.....your gonna spend upward of $3500 for 230WHP?? how about get a T3 slap it on and make that much power, spending half the money on a setup with more potential for power....either way its your choice, but ITB's on a KA are just hyped up, trust me I've been down that route, they sound great and you get great response but in the end its just not enough power. oh yeah and don't forget the crazy lopey cams, Itb is not a great idea for a DD | |
| | #25 | |
| Can speak French....in Russian ![]() | LOL honestly a VQ is a really good idea.
| | #27 | |
| Can speak French....in Russian ![]() | I think you would be surprised what a stock VQ is like in a lightened S13, talk about ready for abuse when you want it!
| | #28 |
| Premium Member ![]() | An SR with a VE head is probably going to be better in the long run if you really really want a NA four cylinder in your car. It might not make the most power straight out of the box, but the potential is higher than a KA. Yes it will require a little work, but heck, it'll be awesome when you're done. I know of many built SRVE's that put down 250+whp. In fact there is an SR23VE that puts down 272whp. You're not going to get near that with a KA. It also revs to 9000+rpm. Which is awesome. Plus you get cool VTAK sounds! Also, you don't have to deal with lame, lumpy cams (you have the low-end cam with a VE). To me, it's the all-around NA four cylinder package. If that's the route you really want to go.
__________________ Support innovation, buy from companies that design their own parts! Suspension before power. |
| | #29 | |
| Zilvia Junkie ![]() | .................. Quote:
__________________ protech-fabrication.com ftw!! | |
| | #30 |
| Zilvia Junkie ![]() | Troy Ermish Racing make ka motors that they run in datsons theat make over 200 wit 10.25.1 cr,370 inj,cams,ported head n a flashed ecu |
| Sponsored Links | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
