| LinkBack | Thread Tools | Display Modes |
| | #1 |
| rebuilt jimwolf KA runs rough. documented tests. I've searched, and read, and tested many systems. Looking for more advice. SYMPTOMS 1. idle is rough, and periodic. smooth, then rough, changing every few seconds. sometimes you may think you hear pop or backfire at idle, but could also be sounds of the engine choking. 2. vacuum gauge inside manifold shows flutter ~3unit only when idle is rough. otherwise steady. 3. pop\backfire can be heard at higher RPM and almost always during deceleration. 4. acceleration is usually nice. 5. power fluctuation can be felt while driving and holding RPM constant, at the same rate as idle fluctuation. CURRENT HYPOTHESIS 's jim wolf pre-programmed on the rich side? there's an air leak im' just not finding it TESTS COMPLETED 1. compression - PASS all cyl ~150 2. air leak - PASS. soaked intake mani and intercooler pipe seals. 3. MAF - PASS. multimeter\blow test on signal wire. 4. Cylinder drop - PASS. all injectors fire. 5. Timing - tuned? Advanced\Retarded timing for best idle. Distributor is on factory tooth, rotated to limit counter-clockwise. An additional tooth in the same direction did not benefit, spooled too soon(?), and ran hot. CONFIGURATION rebuild ka24de yellow top injectors, nismo Z32 MAF jimwolf ATX ECU programmed for MTX GT28 ball bearing turbo intercooler walboro 255 ps. I also see some oil pool up in the turbo inlet/outlet flanges. thanks! steve | |
| Sponsored Links | |
| | #6 | |
| Premium Member ![]() | Quote:
intermittent vaccum leak would be my guess.
__________________ S-Chassis/Z32 Rear Upright Spherical Bearing Group Buy | |
| | #7 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
