| | #1 |
| In time-out for misbehaving. | 1jz swap into s14 ive been searching online and on here with no luck, maybe im not searching good enough because it seems like this would have been talked about. my question is. how easy is it to do a 1jzgte swap into an s14? i mean, other then getting the actual engine, tranny, ecu, harness, etc. what has to be done to MY s14 in order for it to work? if anyone could at least give link to something that covers the entire swap it would be greatly appreciated. im sorry if this is a repost. |
| Sponsored Links | |
| | #2 |
| I <3 LIZMO ![]() | www.myJZswap.com there's alot of help there. basic rundown though. - Mounts both motor/trans mounts. - you will need to run the fuel line to the driversside of the car - heater hoses will need to be done. you will need a new radiator/fan setup. uhm yeah there is alot to do. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
