Ka24de Hello I been having trouble with my S14 KA24DE;
Did a complete tune up Cap, Rotor, Plugs, Plug Wires, Coolant Temp Sensor & Fuel Filter.
car starts but bogs down then engine cuts out.
if I spray starting fluid it runs off starting fluid and idles and revs fine after couple seconds engine cuts out;
I even re-wired Kragen Fuel Pump to 12 volts via Relay it runs a little better but once I rev it, engine bogs down and cuts off.
also if I unplug the MAF plug idle is higher. not so sure if it is Fuel Pump crapping out any advice?
Also while engine is running I pulled each spark plug wire off and its sparking also unplugged each fuel injector wiring while its running there is a different also Fuel Pump sounds kinda weird when at the on position
thanks |
