Old 10-25-2009, 09:26 PM   #1
Sideways_blksr20's Avatar
Send a message via MSN to Sideways_blksr20
fuel pump not turning on by itself
i just did a rb swap and my fuel pump doesn turn on when i tried to start the car ( i cant hear the fuel pump coming on)we tested the fuel pump manually and its working fine but when we try to turn the car on it doesnt go on
we checked fuses
relay
what else shoul we check
thanks
we also checked the wiring and the plug is not getting any voltage
Sideways_blksr20 is offline   Reply With Quote
Old 10-26-2009, 05:33 AM   #2
ANyone??????
Old 10-26-2009, 09:57 AM   #3
Are you getting voltage to the relay? How about the fuse? Did you check your ground?
ericb382 is offline   Reply With Quote
Old 10-26-2009, 03:24 PM   #4
I checked my ground and it reads 12 v I haven't check the relay voltage the fuse is fine thanks
Old 10-27-2009, 06:52 PM   #5
Old 10-27-2009, 08:52 PM   #6
Did you check what he said!?
Check to see if you are getting power to the fuse or relay.
If so, check continuity between relay and pump. Narrow down where you're losing current.
If not, make sure your fuel pump relay output is hooked up correctly on the ecu.
Old 10-28-2009, 03:45 PM   #7
where is the fuel pump relay output?
we havent connect the ecu to the car harness ...could that be the problem
Old 10-28-2009, 04:08 PM   #8
In time-out for misbehaving.
Send a message via MSN to yokotavia
or just hardwire your fuel pump to a switch.
its better to have constant power to it from your battery anyways (when the car is on)
yokotavia is offline   Reply With Quote
Old 10-28-2009, 04:13 PM   #9
mr.booie's Avatar
did you tuck the harness if its lowered? lol. it happend to me.
http://zilvia.net/f/image.php?type=sigpic&userid=70890&dateline=122764  6693
mr.booie is offline   Reply With Quote
Old 10-28-2009, 06:32 PM   #10
thats how i turn on the car the first time i harwire it to a battery
Old 10-29-2009, 09:41 PM   #11
Old 10-29-2009, 11:14 PM   #12
projectRDM's Avatar
How in hell do you expect the ECU to turn the fuel pump on if it's not plugged in? Magic? Pixie dust?
FORMERLY R240NA
Old 10-31-2009, 08:51 PM   #13
Problem sold had a bad relay !thanks
Old 10-31-2009, 11:03 PM   #14
Solve .... My bad
SEO by vBSEO 3.3.0
