| | #1 |
| Premium Member ![]() | SR Vacuum line help Sorry guys, ive been trying to figure this out but i still need some help. Ive looked at the vacuum diagram/vacuum threads/engine bay pics but alot of the info contridicts and/or is a different setup....Thought id try it a different way from the other threads though. So i decided to draw out my setup and ask if someone can fill in the dots(aka vacuum lines). Red=fuel pressure regulator Pink=blowoff valve Purple=wastegate Orange=boost controller Green=boost gauge Quick tap nipple on hot pipe if needed Show where the lines need to be "T" off Thanks ![]() |
| Sponsored Links | |
| | #4 |
| Premium Member ![]() | Thanks for the reply...one of the local guys just sent me the same thing, except he capped the botttom one and "T" the line from the fpr to the boost gauge. So i think i got it now. Im gunna hook mine up after work tomorrow |
| | #5 |
| Premium Member ![]() | Yea vacuum is vacuum. As long as its getting the pressure from the intake its all good. I like to use as many little T's as I can though.
__________________ Nagasaki Motors![]() Friends help you move. Real friends help you move bodies. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
