Old 10-20-2009, 06:41 AM   #1
questions about 1jz swap?
hey whats up everyone im kind of new to this site and was wondering if anyone here did a 1jz swap in a s14? if so i need some help and was wondering if i could just get some questions answered. so if you have done this swap much help will be appreciated. thanks in advance.
DRIFTFORCHICKS is offline   Reply With Quote
Old 10-20-2009, 08:25 AM   #2
TheGuru's Avatar
What are your questions? Your post is rather vague. Better to post your questions so you can get more direct answers.
TheGuru is offline   Reply With Quote
Old 10-20-2009, 09:05 AM   #3
PM me with All your` questions....i'll be happy to help,
(i'm swapping 2JZ-GTE in my S14 as we speak)
Regards,
Ali
'95 S14 Se With HKS's - BREMBO's - ES/SPL.
Ali 556 is offline   Reply With Quote
Old 10-20-2009, 12:33 PM   #4
alright here are some of my questions.
-what shifter do i use in the shifter exstension from 2jz swap. com?
-will the usdm 2jz tps work with the 1jz?
-is the clutch assembly the same for the r154 trans? or is it different since its going on the 1j? so do i need the clutch release hub and those misc. washers?
thats all i could think of for now but will post more later but thanks for the help
Old 10-20-2009, 08:45 PM   #5
blkkouki's Avatar
pm me, as I'm in the process of doing a 2JZ swap
blkkouki is offline   Reply With Quote
Old 10-23-2009, 02:54 PM   #6
still need help.
Old 10-25-2009, 12:55 PM   #7
Have you purchased anything yet? You have 2 choices when it comes to shifter you could buy the one from 2jzswap or try to locate a r154 with the shifter exension on it already(rare) but they can be found.
Not sure on tps sensor I assume it would work okay try searching the forum over at supramania.com you'll get better answers over there since they have dedicated 1jz/2jz section.
Clutch assy is the same, the flywheel is different.....washers???
cole d is offline   Reply With Quote
SEO by vBSEO 3.3.0
