| | #1 |
| Zilvia Junkie ![]() | Revvs hover when pedel is released So this may be a pointless thread but i did a little searching and it didnt really come up with anything useful so here we go. 92 KADE, exaust, intake filter. When i hold the revvs at say 1500 for a few seconds, and let of the pedel the rps's will just hover at that exact sopt for 2-4 seconds then drop. this points me to 1. Vaccume leak 2. Injector leak I bring up injector leak since i have had problums with that in the past, And i have also delt with a nasty vaccume leak from my egr. Now what puzzles me is the car idles at 800rpm pretty steady, it dose have some studering and "jumping" you can feel in the car. the car also failed smog pretty bad and is showing a "egr" and "knock sensor" code. And when i had my vaccume leak the car would idle super high, and this is not the case at all here once the car warms up the idle is at the right number. When i had a leaky injector it was expelling alot of black smoke and almost dieing. Wich its not at all doing now. So before i start ripping things apart, Has anyone had a problum like this and could point me in the right direction? i can make a video if need be. thanks in advance ![]()
__________________ |
| Sponsored Links | |
| | #4 |
| premium bullsh!t sifter ![]() | Fix the problems/codes first. Just try cleaning the EGR free of carbon and make sure the actuation of the valve is free. also check the diaphragm for proper function. Replace the knock sensor. A vacuum leak is very possible. If the symptoms persist, also clean and test the IACV and look at the vacuum components on the back of the head. ~mario
__________________ Don't Know How To Install? IM/PM Read My Sales Review 626 Friday Nights San Gabriel |
| | #7 |
| Zilvia Junkie ![]() | I might, i had to replace mine, and the one i baught had the same #30 on it as my old one, he said it was a 5 speed ecu, but im not 100% on that maby this will help, sometimes it will randomley revlimit me at around 4.8k ish
| | #10 | |
| Nissanaholic! ![]() | Quote:
cuz if u do have an auto ECU, it will hold idle high for a sec or two then drops to normal but try to clean out ur EGR tube if ur getting a Code from the ECU for that and replacing the knock sensor isnt as hard as you think u can actually get ur hand underneath the intake manifold and get the KS in took me about 20min max... if you need to ill meet you in riverside and show u how...lol
__________________ 91' 240sx Fastback | |
| | #11 |
| Zilvia FREAK! ![]() | also when cleaning out the IACV spray some carb cleaner down the big hose and let it sit for a few minutes, or take it off the intake manifold if you like, but its a bitch to get at while still on the car. |
| | #14 |
| Zilvia Addict ![]() | people that say stupid shit like that make me wish i never bought my 240 in the first place. i bet your car is a POS joey, if you need help with your car man feel free to bring it by my house.. you know where i live lol |
| | #15 |
| Leaky Injector ![]() | waht difference does it make if your idle is off for 2 seconds. your one of those people who buy 240's and expect them to run like a ferrari
__________________ Team Redline Slideways |
| Sponsored Links | |
| | #16 | |
| Zilvia Addict ![]() | Quote:
no im one of those people who buy a car and make sure it runs properly. i dont half ass shit.. if something is wrong, fix it.. if not let it be. in this case something is wrong dick | |
| | #17 | |
| Zilvia Junkie ![]() | Quote:
and yea i agree. i got this car with a bad engine, bad tranny ect.. and im doing what i can to make it roon as good as i can.. why evin buy a 20 year old car with the intent of makeing it nice and say meh its a 240.. lots of poeple have crappy 240s so that makes it ok for mine to be crappy... annnyway yeah nick i might come by one day, bring some are approved bevrage and rip off my intake side..
__________________ | |
| | #18 |
| idle It still sounds like a small vacuum leak. Knock sensor does not have anything to do with idle. If it was EGR it would idle very rough and die. I stiil think you have a vacuum leak. Call a few shops in your area and ask if they can do a smoke test on the intake system. It only takes a few minutes and takes all the guess work out of the way. It will pinpoint your leak. After that recheck, timing, and base idle. | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
