Old 10-19-2009, 10:02 AM   #1
Head gasket help ka .02 bore
Hi guys I need help finding a head gasket for my ka24de with a over bore of .02. I cant seem to find a head gasket to match a 89.5 bore anywhere on the internet, the only hg i find are 89mm, 90mm, and 91mm. Would it be safe with going with a MLS head gasket with 89mm? Someone please help me.
ForcedNduction is online now   Reply With Quote
Old 10-19-2009, 10:38 AM   #2
Sileighty_85's Avatar
get the 90mm. It being a little big wider wont hurt anything
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Sileighty_85 is online now   Reply With Quote
Old 10-20-2009, 12:24 AM   #3
+1 Most HG's are .5mm larger than advertised anyway just to gain clearance/make sure it's mating on the flat surfaces etc. It's well accepted and would be the recomended size by the manufacurers.
ericb382 is offline   Reply With Quote
Old 10-28-2009, 12:50 PM   #4
yeah just make sure everything is resurfaced with the kind of hg or youll get leaks.
jdm213 is offline   Reply With Quote
Old 11-17-2009, 03:37 AM   #5
I had the machine shop mic check the bore and thickness of the old headgasket. Turns out it was a 90mm bore with a thickness of 1.14. I have a new cometic hg on order Thanks for all the help
Old 11-18-2009, 11:04 AM   #6
go with 90mm to make it snug if you go with the 89, you may have little leaks, but with the 90 it will all be snug.
89.5, head gasket, ka24de, ka24de-t, ka24det
SEO by vBSEO 3.3.0
