Old 10-18-2009, 09:13 PM   #1
jonnybonds84's Avatar
Oil pan leak, again after reseal. HELP ME JESUS!
Can any one come up with a reason why my oil pan is leaking in the front of the engine almost in the same spot. I had a fel-pro gasket last time and this time I thought I would just use high temp silicone. Does anyone have a pic of the bottom of the front cover? When I changed my gasket I thought the bottom of the front cover was way too smooth so I roughed it up with some sand paper. I don't know why it's only int he front of the engine, can the oil pressure be too high or something else. Thanks in advance for the help.
J
jonnybonds84 is offline   Reply With Quote
Old 10-18-2009, 09:58 PM   #2
VIPremium Member
S14_Kouki's Avatar
No it will not be cause of oil pressure. From the factory they come with silicone. Just re-seal it again and if that does not work maybe you are leaking from the front main. Heres your pic.
S14_Kouki is offline   Reply With Quote
Old 10-18-2009, 09:59 PM   #3
VIPremium Member
S14_Kouki's Avatar
PS use a decent amount of silicone and let it dry before you start it up and make sure the surface is clean.
Old 10-18-2009, 10:12 PM   #4
Sileighty_85's Avatar
DO NOT USE HIGH TEMP RTV!!!
It will leak every time!!!
Every person i see that uses this stuff on oil pans it leaks
Just because the engine get hot does not mean you need to use high temp
Use Black Prematex RTV
http://www.permatex.com/products/Aut...sket_Maker.htm
I use this RTV on every oil pan i have done and not one of them has leaked
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Old 10-18-2009, 10:14 PM   #5
Surface was extra clean (made sure of it), used a decent amount (made sure of it), and I left it a day without oil before starting it up.
J
Old 10-18-2009, 10:16 PM   #6
Any one else had this problem with the RTV????? Never heard that this would be a problem, some people recommend it. Last time I used normal kind I believe and it leaked.
J
Old 10-18-2009, 10:19 PM   #7
Kinda hard man for it not to work right, all you gotta do is apply RVT, bolt up, let dry
I guess....
Make sure the oil pans lip isnt dented?
後輪駆動車1番
Old 10-18-2009, 11:35 PM   #8
That may be it too, looking to buy a new one this time around.
J
Old 10-19-2009, 12:47 AM   #9
VIPremium Member
S14_Kouki's Avatar
I was going to say this but forgot lol sorry but yes check that.
Old 10-19-2009, 01:33 AM   #10
premium bullsh!t sifter
let5l1de's Avatar
Send a message via AIM to let5l1de Send a message via Yahoo to let5l1de
It is also common to slightly warp depending on conditions such as loose pan subject to heat, many rebuilds with same pan, improper torque or tightening sequence, improper torque with cork or rubber gaskets. The front cover area and rear main area are typical areas of gasket failure when additional blow-by is experienced within the engine.
Get a straight edge and check the surface for any inconsistencies.
Also, fully clean the old sealant from the pan and properly apply the continuous bead within the sealant holding depression on the lip of the pan.
btw:
As an engine builder of over 17 years, I do agree that the Ultra Black Oil Resistant Permatex is best. But most RTV in hi-temp or standard gasket maker compounds will typically be fine as well.
Don't Know How To Install? IM/PM
Read My Sales Review
626 Friday Nights San Gabriel
let5l1de is offline   Reply With Quote
Old 10-22-2009, 06:05 PM   #11
jr_ss's Avatar
Try using some acetone to remove any oil/grime from the surface desired to be RTV'd. I use the Ultra Gray RTV made by Permatex, it's what Nissan uses as well.
Built 95' S14....
jr_ss is online now   Reply With Quote
Old 10-31-2009, 11:57 AM   #12
Has any one heard or seen warpage on the bottom of the front cover???? I just bought a new oil pan and I praying that this will fix it because it's going to suck major ass if it's the front cover.
J
Old 10-31-2009, 12:12 PM   #13
CinSun's Avatar
btw:
sorry, i don't mean to threadjack, but would you recommend using the ultra black permatex for sealing the front cover as well?
CinSun is offline   Reply With Quote
Old 10-31-2009, 12:12 PM   #14
KFLS14's Avatar
btw:
Ultra Black Oil reistant +2 I removed my buddies old pan it was stuck on pretty good. I noticed though 1 said oil resistant and the other didn't not sure if its just labeling or possibly different. Napa/Autozone.
S14a Stock
KFLS14 is offline   Reply With Quote
Old 10-31-2009, 12:45 PM   #15
I used the same thing on my gf's sr and it has no leaks at all.
BlitzRPS13 is offline   Reply With Quote
Old 10-31-2009, 03:23 PM   #16
Can anyone answer the front cover question? I've never heard of it.
J
Old 11-01-2009, 12:36 AM   #17
The front cover does not matter as long as its clean, then after getting all the old stuff off use some brake clean or i use paint prep cleaner and get ALL the stuff off even if you cant see the oil there is still some there trust me. Then apply a nice bead of gray RTV to the oil pan and screw the bolts in FINGER/HAND tight only! ( i know the package says this part is not necessary but i do it and it has never leaked once) Let it sit for 1 hour then come back and tourq them down to spec, if you over tighten it will just push all the RTV out and auctially seal worse then if you did it to spec.
brian3676 is online now   Reply With Quote
Old 11-01-2009, 12:11 PM   #18
Zilvia Contributor
mbmbmb23's Avatar
Definitely let the RTV set up as a bead before you torque it to spec so it compresses uniformly when tightened.
400x200
mbmbmb23 is offline   Reply With Quote
Old 11-18-2009, 12:12 AM   #19
I got my new oil pan from FR sport but now that I got it it looks like the pan got kinda banged up and I wondering what every body thinks. the back of it seems to be a little warp and now I worried it might leak from the back. Let em know if you guys think I should be worried.
This the front where it straight with no worries. This is where it was leaking before.
J
Old 11-18-2009, 02:04 PM   #20
No one has any opinions on this?
J
Old 11-18-2009, 03:50 PM   #21
ManoNegra's Avatar
Send a message via AIM to ManoNegra Send a message via Yahoo to ManoNegra
I wouldn't, use the gray one since it's made to imports' specs including Nissan.
only way that we stopped oil pan leaking on our motor builds
was to use the Felpro gasket along some RTV
make sure to follow the FSMs torquing procedure
also could be a leaking front main seal, very common problem on KAs
Old 11-18-2009, 04:01 PM   #22
Uh, it doesn't look straight to me. Talk to frsport.
For Sale: sr head, internals, etc... PM ME!
VNG704 is offline   Reply With Quote
Old 11-18-2009, 08:38 PM   #23
After I straighten it out, what do ya'll think.
J
Old 11-18-2009, 10:27 PM   #24
sound be fine. try to get a torque wrench in there and tighten it down to 12lb.
AznXstazy is offline   Reply With Quote
Old 11-18-2009, 10:52 PM   #25
The FSM says it should be 4.7-5.5 LBs. That much would squish out the RTV and warp the pan I believe.
J
Old 11-18-2009, 11:00 PM   #26
my bad, i just went with the torque i have on my valve cover, but that has a rubber gasket thought it be the same, but ya just torque it he same amount of torque and you should be good to go. just don't go crazy with the RTV
SEO by vBSEO 3.3.0
