Old 09-15-2009, 02:47 AM   #1
pyshin's Avatar
Arrow sr20det cold starts
Yes, I have searched and havn't found much help.
I have a redtop sr20det in my '89 hatch and it has horrible cold starts. The battery and ground are fine. The starter has no problem turning the engine over. The engine starts up no problem when warm. I believe it may be a problem with fuel delivery, but I really don't know. If you guys have any input I'd appreciate it. Thanks
'89 S13 SR20DET
pyshin is offline   Reply With Quote
Old 09-15-2009, 03:04 AM   #2
skylindrftr's Avatar
have you tried petting it =P
skylindrftr is offline   Reply With Quote
Old 09-15-2009, 06:28 AM   #3
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
Define bad cold start? Like having a hard time cranking over when its cold?!?! Do you have to gas it to start it, and keep gassing it till it gets somewhat warm???
Old 09-15-2009, 06:33 AM   #4
[JEFE S14]
GSXRJJordan's Avatar
Send a message via AIM to GSXRJJordan Send a message via MSN to GSXRJJordan
Did you do the wiring yourself?
Theres an orange wire/silver stripe that connects to the dash harness (small white rectangular plug) that a lot of people don't hook up. It gives the ECU +12V on that pin when the engine's cranking, so it dumps fuel into every injector instead of just one, helping the engine 'catch'.
FRSport's S13 SR into S13 writeup covers it well, with pics.
TEAM SUS*PECT is alive.
www.JordanInnovations.com
Old 09-15-2009, 10:15 AM   #5
pyshin's Avatar
It doesn't have a hard time cranking when cold; and I don't have to keep it gassed, just idles at a higher rpm when cold.
No I didn't, my car came with the swap complete
Thanks, I'll look into that and update the thread later
'89 S13 SR20DET
Old 09-15-2009, 02:29 PM   #6
wait.. bro, are you saying that it just IDLES HIGH when engine is cold?!?!
Does not have a problem starting when cold.
Does not have a problem starting when warm.
Just IDLES HIGH when cold.
my next question, does the HIGH idle go down after a couple of minutes when the engine gets warm?
HAWAII is offline   Reply With Quote
Old 09-15-2009, 02:40 PM   #7
pyshin's Avatar
No, it does have a problem starting when cold AND idles high as engines usually do when cold.
It has no problem starting when warm.
Yes, the idle goes down to around 750-775 rpm when warm.
'89 S13 SR20DET
Old 09-15-2009, 03:27 PM   #8
How high is the idle cold? I saw it at like 2k, but i think you were gassing it? Usually the car just idles high until it warms up Peter.
Old 09-15-2009, 03:29 PM   #9
pyshin's Avatar
Around 1300. I know it idles high when warming up.. That's not the problem Avery. Haha
'89 S13 SR20DET
Old 09-16-2009, 02:45 AM   #10
Lol okay, did you check the wiring thing the other guys were talking about?
Old 09-16-2009, 04:24 AM   #11
[JEFE S14]
That actually removes the coolant temp sensor from the list of possible problems. If you want to roll out to my garage in the 626, I can diagnose it for ya, and fix it if needed in less than an hour.
PM me if you need more help than the FRsport guide gives.
Old 09-16-2009, 07:56 PM   #12
Give it a shot if you can't do it yourself peter, jeff is legit =)
Old 09-17-2009, 01:38 AM   #13
sig test, sorry peterrrrrrrrrrrrrrr
Old 09-17-2009, 01:39 AM   #14
pyshin's Avatar
How many times do you need to test it lmfao
'89 S13 SR20DET
Old 09-17-2009, 02:16 AM   #15
pyshin's Avatar
Cold starts have been fixed. Used Chevron Techron fuel system cleaner and now it's fine. Must've just been dirty injectors
'89 S13 SR20DET
Old 10-13-2009, 06:00 PM   #16
pyshin's Avatar
Cold starts are back. Any suggestions?
'89 S13 SR20DET
Old 10-15-2009, 05:44 PM   #17
extra20's Avatar
check ur FPR on few occasions debris can lodge in diaphram and cause fuel pressure to drop when parked for a few hrs or usually overnight. so the engine will act similar to a lawn mower when it runs out of gas surge then dies. in ur case it s pressure up then stabilizes.
extra20 is offline   Reply With Quote
Old 10-15-2009, 05:48 PM   #18
extra20's Avatar
disconnect the vacuum line to FPR and see if theres fuel in it should be dry.
Old 10-15-2009, 07:44 PM   #19
pyshin's Avatar
Just checked, it's dry.. Dammit haha
'89 S13 SR20DET
Old 10-15-2009, 08:40 PM   #20
jspaeth's Avatar
This is the first time I've heard this, and might be the reason why sometimes my f.p. is down a few psi every once and a while when I start the car.
But how could anything get into the FPR? If you have a well-functioning fuel filter, how can anything large enough to "lodge" in the diaphragm get in there in the first place....?
Picture Me Rollin'
jspaeth is offline   Reply With Quote
Old 10-15-2009, 10:04 PM   #21
pyshin's Avatar
No idea. Also changed my Z32 fuel filter the other day..
'89 S13 SR20DET
SEO by vBSEO 3.3.0
