Old 09-03-2009, 12:36 PM   #1
Nibras's Avatar
Send a message via AIM to Nibras
Exclamation this has me beat!
I switched wireharness and ecus , and now my maf and air intake sensors are not being read, I tried another maf, and nothinggg, input?
Nibras is offline   Reply With Quote
Old 09-03-2009, 04:48 PM   #2
projectRDM's Avatar
There must be damage in the harness. The two sensors are unrelated except for their location, and only the MAF has any effect on engine operation.
Why did you swap all this again?
FORMERLY R240NA
projectRDM is online now   Reply With Quote
Old 09-03-2009, 08:17 PM   #3
Nibras's Avatar
well the. harness I had in was. missing a lot of sensors, everything did worrk fine beforee
Old 09-03-2009, 08:26 PM   #4
lazysk8er2's Avatar
need more info about whats going on but could be a fuse or check the grounds.
Yea sure its a stock turbo...
lazysk8er2 is offline   Reply With Quote
Old 09-03-2009, 11:38 PM   #5
Nibras's Avatar
wich fuses would be checked and what grounds. is there any specific grounds for the harness besides the main ground , anyone near the ecu?
the car is basically running like it would without the maf, when I hit 2500 rpm it just starts bouncing and I hear air pops.
this ecu n harness is from a 95, my car is a 96 ,
Old 09-04-2009, 07:54 AM   #6
lazysk8er2's Avatar
ok dude this is the internet and i dont know who u are and what you have in your car you need to be more specific. did you do a swap and into what or is it a stock ka. its hard to help with one sentence questions with no info.
1) you may have the wrong ecu.
2) the two mafs you tried could have been busted.
3) if you did a swap and did the wiring there may be a break or something is grounding out or two wires rubbing before it goes to the sensor.
4) check all your fuses with a test light.
5) the new harness, was it used?
6) who did the wiring.
7) did you solder it or use connectors.
8) check all the connections.
9) check you wired the plugs on correctly.
Old 09-04-2009, 06:58 PM   #7
Nibras's Avatar
problem was solved! it was a small ass wire on the harmess under the electric tape was cut.
240sx, ecu, obd, s14, stuck
SEO by vBSEO 3.3.0
