Old 08-15-2009, 11:35 PM   #1
Mista Lee's Avatar
Send a message via AIM to Mista Lee
s13 KADE Help
So after deciding to clean the throttle body with some throttle body cleaner, my engine's been acting up randomly.
At random times, the car would have very rough idle, and havewould sound similar to the sound of an STi. I've checked the injectors/spark plugs, but they all seem to be fine.
As mentioned above, this happens at random and often.
PbNation.com l NikeSB.org l POTN
Mista Lee is offline   Reply With Quote
Old 08-15-2009, 11:39 PM   #2
Sileighty_85's Avatar
Make sure no vacuum line poped off
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Old 08-16-2009, 07:11 PM   #3
The Cook
DALAZ_68's Avatar
Trader Rating: (77)
check that u didnt mess up the gasket...and air lines
LOL 240...
my seller review thread
XBL GT : Wh0pp3r68
Old 08-16-2009, 10:07 PM   #4
Mista Lee's Avatar
vacuum lines are all fine
i'll check the gasket in a bit
Old 08-16-2009, 10:13 PM   #5
Okinawandrifter87's Avatar
Send a message via AIM to Okinawandrifter87
By chance did you check the wire set running to the spark plugs? Also yeah check for vaccum leaks egr in the back of the block by chance.
JDMwerks
Okinawandrifter87 is offline   Reply With Quote
Old 08-16-2009, 11:39 PM   #6
hOngsterr's Avatar
running on 3 cylinders,
if you checked ur injectors one by one,
check your park plugs and wires. both not just one or the other,
i had similar things like you, when i fixed the plugs and wires it ran super nice.
but my car's going crazy again with the idle, i suspect it might be my Coolant Temp Sensor messing with it so ima go buy another.
89 FB DD/DELAYED PROJECT.
SEO by vBSEO 3.3.0
