Old 08-15-2009, 04:33 PM   #1
timing is off on my sr20det
i just bought this 240 with a sr20det in it and the guy said he had a new head gasket put in and the guy who did it didn't get the timing right, so how do i fix the timing, should i start by pulling the front and valve cover off and make shure the timing chain is set right with the cams and crank first.
sembrick is offline   Reply With Quote
Old 08-15-2009, 04:42 PM   #2
Sileighty_85's Avatar
you can pull the cover for a sure fire way or
set to TDC
set at 9 and 3
Count links
then turn over by hand to make sure valves do not make contact with pistons
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Old 08-15-2009, 07:53 PM   #3
thanks man i will try that
Old 08-19-2009, 01:34 PM   #4
do you know if the head is a zero clearance
Old 08-19-2009, 06:17 PM   #5
its an interfering engine
後輪駆動車1番
timing
SEO by vBSEO 3.3.0
