| | #1 |
| HELP!!! fried tach signal resistor in rb ecu.. PLEASE LOOK!! So I just did the maxima tach (pretty sure its the same exact tach as the I30) swap in my sII rb25 s13. When the needle didnt even react, I put the stock dohc tach back on and it still didnt react. This was weird considering there was a signal before, even though it was very wrong with the stock tach. So I opened up my ECU and found this: look just above the 6 white things ![]() just above r414 and just below r313 ![]() As you can see, it's pretty fried and unidentifiable. So what I need is for someone to PLEASE open up their ECU and identify it for me or even post up pictures of it. I was going to see if I can salvage this ECU before looking for another one. Thanks ahead of time. Last edited by platez808; 08-13-2009 at 06:33 AM. | |
| Sponsored Links | |
| | #4 |
| [JEFE S14] ![]() | If you're thinking of replacing that resistor, don't bother. Much easier to get a tach-signal-generator that connects to the #1 coilpack wire for $20. Hope the rest of the ECU is OK. BTW, you could have used a timing gun/etc to calibrate the stock tach down to be correct on the RB ![]() |
| | #5 | |
| Quote:
Haha.. that's news to me.. where were you in the million "RB swap tach fix" threads?? can you please explain how? | ||
| | #6 |
| Also, while i was taking a closer look at it, i traced the connections from that fried resistor and i found this on the other side.. look at t450 ![]() i guess i need help identifying this too.. again thanks ahead of time | |
| | #7 | |||
| [JEFE S14] ![]() | Quote:
Click here. DEI (Directed) is the largest car audio/security manufacturer around, they make one that has been on the market for 15 yrs or so lol. Part number 454T, any car audio shop can order it for you, or you can use the link above to find it for like $20. Quote:
My recommendation is to see if the ECU still works, and if so, leave it alone. | |||
| | #8 |
| man i'm stuck.. i tried using a tach signal generator hooked up to the #1 coilpack wire instead of relying on the ecu for a tach signal but theres still no luck.. i took a multimeter to the tach signal wire while it was hooked up to the tach but not to the ecu.. and it was putting out like 8 volts when in on and 12 volts when it the engine was running.. does anyone know if this is correct? it doesnt make sense to me that there would be any voltage with the signal wire hooked to the tach but not hooked up to the ecu.. someone help me out here | |
| | #9 |
| well i just went and bought a new ecu and it works fine now.. for the record its a series I ecu running a series II motor but i also now have the part numbers for the fried stuff, so i'm going to see if i can source those parts and then replace it and see if it fixes it.. | |
| Bookmarks |
| Tags |
| ecu, rb25, rb25det, tach, tachometer |
| Thread Tools | |
| Display Modes | |
