| | #1 |
| Leaky Injector ![]() | Does anyone know were i can get camshaft bearings for my ka24e at? ive already check my work (Kragen auto parts) ipp.com, and ive googled it it. and i cant find some anywere, im replace my cam and i wanted to get new ones, any one have any part numbers?
__________________ keeping it gangster |
| Sponsored Links | |
| | #3 |
| Leaky Injector ![]() | no i thought there were camshaft bearings on the bearing caps above the camshaft?
| | #4 |
| Zilvia Junkie ![]() | i dont think the "bearings" for the cams are replacable....well at least they arent for SR. im pretty sure that the KA is the same though. The Cam's Bearings are a machined surface in the head and the acutual cam cap. there arent bearing "shells" that you can replace. thats not to say you cant maching the bore and find some shell that will fit in. |
| | #5 |
| Zilvia Junkie ![]() | no there isnt. the cam caps are machined alum and fit right to the cam itself. |
| | #6 | ||
| Leaky Injector ![]() | Quote:
thanks, guys, now im putting in a nismo cam, think i should buy new cam caps? or just install the cam with the old caps on. lmk thanks alot for the help dave
__________________ keeping it gangster | ||
| | #7 |
| Zilvia Addict ![]() | You can't just install new caps and run with it. You'd have to have them line honed. Keep the old ones, put them in where you took them off and go read a book on engines..
__________________ Built 95' S14.... |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
