| | #2 |
| Zilvia Junkie ![]() | Your supposed to make it read 0.44 volts I do believe but I have seen many times where that is not low enough. I know for a fact mine has to be below.4 or it will not tell the ecu the tb is closed. The best way is to do it while having a computer hooked up through consult. Then you want to see it say that the tps is closed when it actually is. If you have a wideband fuel should be cut when over 1500-1800 rpms and when below that fuel should come back in then. |
| | #3 |
| ok i got another question i went out and got the 91 sentra se-r tps cus i thought it was the same thing but mine has 6 wires and the se-r has only three so did i get the wrong 1 or do i have to change the tps to 3 wires? | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
