Old 07-03-2009, 01:21 AM   #1
Dee
Dee's Avatar
SR sputtering in higher RPMs
OK so I took my car to the track tonight and I notice that every time I get around 5k rpm in 3rd gear my car sputters and loses power and it does it to redline. I'm running stock t25 turbo @ 10psi(no boost controller), 255lph fuel pump, stock FPR, ARC SMIC, stock bov.
I was thinking maybe plugs since I haven't changed them since the motor swap, but I thought I'd get a second opinion.
thanks
-Dee
My best run tonight but still slow because of the high rpm sputtering:
Dee is offline   Reply With Quote
Old 07-03-2009, 01:38 AM   #2
Felipe's Avatar
maybe spark plugs... check your battery connections, my bro inlaw sr was doing that... posi cable was loose. lol hope that helps
NO MORE S13, but im still on here
Felipe is offline   Reply With Quote
Old 07-03-2009, 01:40 AM   #3
Wrinkle Red = Vtak
VQMaxFan's Avatar
Send a message via AIM to VQMaxFan
yeah check the plugs, make sure the gap is set properly.
VQMaxFan is offline   Reply With Quote
Old 07-03-2009, 01:48 AM   #4
Dee
Dee's Avatar
what would be the best spark plug gap to set at? thinking about doing oil change & new plugs tomorrow.
Old 07-03-2009, 05:41 AM   #5
[JEFE S14]
GSXRJJordan's Avatar
Send a message via AIM to GSXRJJordan Send a message via MSN to GSXRJJordan
Yup, plugs are the first thing to check since a) they're an "unknown" when you get the motor, and b) they're cheap
Heat range 7 is what you're looking for, copper is fine (Iridiums perform the same, just for longer intervals - copper's good for >10k mi). Gap to .032", or 0.8mm.
TEAM SUS*PECT is alive.
www.JordanInnovations.com
Old 07-03-2009, 01:21 PM   #6
Dee
Dee's Avatar
Just picked up some oil & Ngk7r's from napa I'll update later tonight with the outcome. Thanks for the help
Old 07-03-2009, 01:32 PM   #7
s13_kidd's Avatar
hey braaahhh i saw you shooting that fireball at irwindale last night ahaha
11/88 - july 02, 2009. i miss you two-tone
s13_kidd is online now   Reply With Quote
Old 07-03-2009, 01:58 PM   #8
lilrusty's Avatar
if not your plugs then it might be one of your coils going out. happened to a buddy of mine. same problem as yours. we swapped out and problem went away. good luck...
lilrusty is offline   Reply With Quote
Old 07-03-2009, 03:53 PM   #9
[JEFE S14]
True. With RB coils, it's fairly common on higher mileage motors for the insulation to wear thin, causing the coil to arc through the black rubber to the head, instead of delivering all of the spark to the plug. If plugs (properly gapped) don't fix it, try wrapping each coil in electrical tape where it meets the head.
Old 07-03-2009, 06:17 PM   #10
Dee
Dee's Avatar
haha word, it was a fustrating night for me but I'm glad my boy caught that flame. Preety cool heh
I'll check the coils insulation out but since I already bought new plug I'm just gonna go ahead and swap them but I will check the gap of the old ones before I put them in.
Old 07-03-2009, 11:38 PM   #11
Dee
Dee's Avatar
Well I found out what was causing my topend sputters and I'm almost too embarrassed to post it.
Turns out that it was a loose ground cable, the post on my battery wore down and I guess from racing last night it worked itself loose and was barely making contact.
Old 07-04-2009, 12:32 AM   #12
[JEFE S14]
Haha, at least you've got new plugs
SEO by vBSEO 3.3.0
