| | #1 |
| JdRft. Jdm Concepts ![]() | So i have a blacktop sr20det has full turbo back exhaust,stock smic,and piping,greddy type r bov,manual boost controller and walbro 255 fuel pump... This seems to always happen on cold startups or randomly sometimes... when i go to startup the car it starts and idle/bogs like at 300-450 rpm then dies i have to start it about 4-5 times sometimes before it starts and idles good! after it starts it runs perfect spools nice everything....anyone might know what i can do to solve this problem any help will be much appreciated ![]() when it starts i have a vaccum of 18 so seems liike vaccum should be ok.. battery is good.. fuel pump sounds fine..
__________________ sounds like a trex lives under my hood |
| Sponsored Links | |
| | #4 |
| JdRft. Jdm Concepts ![]() | i threw on a redtop ecu because mine has no led light and it ran a code 55 which i believe means no error... and too check the fuel regulator.. how would i check that??
| | #7 |
| JdRft. Jdm Concepts ![]() | so i still get problems at cold start ups! the car will turn on and stumble around 400-500 rpms then after about 4-5seconds it shoots up to 1100 and its fine!! any ideas on what it could be? i knw its suppose to start up right away!! someone mentioned fuel regulator! how would i check that? i also have a vaccum of 20 does that matter? isn't suppose to be 18? thanks in advance
__________________ sounds like a trex lives under my hood Last edited by silverman182; 08-02-2009 at 05:36 PM. |
| | #8 |
| I don't have all the info as i am just an apprentice, but if your running a stock reg or any vacuum operated unit you can use a vacuum pump and see if it hold vacuum. Also if the fuel rail you are using has a shrader valve on it you can hook up a fuel pressure gauge and watch it at start up. Good luck! | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
