Old 05-20-2009, 10:45 AM   #1
JRS90FASTBACK's Avatar
Changing gears then engine goes "limp"
I'm new here so cut me a little slack Okay so I drive my 90 hatchback mostly everyday. So when I'm driving sometimes I'll be in second, shift up to 3rd and the car will just go limp. I'll pop it out into neutral and back into 3rd and at times it'll feel like it's starting to run but then it goes limp again. Btw this doesn't just happen in 3rd. I doubt it's the clutch because I just got it new literally a month ago. Before when I gave it gas it would sometimes jerk but it hasn't done it recently. Also the engine has a rough idle.
I've been noticing that my fan has been getting dirtier with like black smoke but it looks like dust on the fan. I checked the oil this morning and it's kinda low. Any ideas what could be up? Oh and when I went to my friend's shop they told me that I needed to replace something like a TPS? Throttle something something. It's like a little black square on the front left side of the motor. They said it needed to be replaced and adjusted. But they also told me that it wouldn't affect my car other than using a bit more gas. Help?
JRS90FASTBACK is offline   Reply With Quote
Old 05-20-2009, 08:55 PM   #2
Solidus311's Avatar
Don't know what your problem is, but I do know what TPS stands for: Throttle position sensor. I also don't know if that will fix your problem. Here's a link for a new one nonetheless. RockAuto Parts Catalog
Good luck to ya.
cardomain.com/ride/3113705
Solidus311 is offline   Reply With Quote
Old 05-21-2009, 12:41 AM   #3
Fonix36's Avatar
Send a message via AIM to Fonix36 Send a message via Yahoo to Fonix36
that thump may be a backfire. is the car modded in any way
Hit me up on Myspace
Originally Posted by 1QUICK4 View Post
then you throw lube into the subject and wonder if it has enough.
DRiFT 4 A Cure!
Fonix36 is offline   Reply With Quote
SEO by vBSEO 3.3.0
