| | #1 |
| NEED HELP PLEASE!!! with my sr20det spits and spuders. well i bought the car from a friend and it was running great like a freaking champ. but then i had the bright idea of doing a tune up on it and i replaced the oil filter, oil, and spark plugs. I went wrong when i changed the the plugs from heat range 7 to heat range 5. thats when it started to spit and sounded like it back fired. i changed the plugs to heat range 9 to see if it would get rid of the problem and it didnt so i put in the originals heat range 7 and it just minimized it but its still there. can anyone help??? | |
| Sponsored Links | |
| | #4 |
| SLINKY + ESCULATOR = Fun Times ![]() | Why the fuck would you run 9 heat range spark plugs? Rule of thumb...6 for stock, 7 more slightly modded, 1 higher heat range for every 100 hp you make. For you to run 9s, you better be making over 450. Go look for some BCPR73S-11s, double check the gaps at .028-.030.
__________________ |
| | #5 |
| the reason i changed it to 9s were cuz a friend that had the same problem told me it worked for him.... my boost is at like no higher than 8 psi i cant gap the plugs cuz there ngk iridiums. what i think it is also is it might be my coil packs sense they look really bad... | |
| | #6 |
| SLINKY + ESCULATOR = Fun Times ![]() | You can gap iridiums, just be careful not to nick the tips...so again, stock setup, stock boost, 9s will make it run like shit. BCPR7ES-11s, $1.25 per sparkplug...fuck all that noise with iridium shit, cheap enough for you to order a box of them for the price of 1 iridium plug.
| Bookmarks |
| Thread Tools | |
| Display Modes | |
