Old 05-12-2009, 03:53 AM   #1
sr help! most likely boost leak!
i was driving home the other night from work and all of a sudden my car started bogging, sputtering. i stopped checked it out for any leaks and seems fine then i drove the car home bogging sputtering the whole way home! this morning i turned my car on i notice my vacumm is at -10psi, if i am correct it should be sitting at -20psi. i checked intercooler piping, i've swapped fuel injectors, fpr, checked all vaccumm lines and still nothing! it just gotten worst this morining so bad that i cant even drive my car. could it be that my bov can cause this massive leak or my boost controller seloniod? or is problem somewhere else?
nissan240 is offline   Reply With Quote
Old 05-12-2009, 06:43 AM   #2
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
Pressurize the system...you have a leak somewhere...
fliprayzin240sx is online now   Reply With Quote
Old 05-12-2009, 01:18 PM   #3
how would i pressurize the system? also could it be my spark plug? ngk iridium heat range 8! my motor is built stage one port and polish on intake side, stage 2 on turbo side, i got camshafts, springs, retainers, guides, pistons rods etc. etc.
Old 05-13-2009, 10:41 AM   #4
If your still running a stock turbo, you dont need 8s. Get some 7s and make sure theyre gapped .028-.030.
Old 05-13-2009, 03:22 PM   #5
i have a hks gtrs turbo.
Old 05-13-2009, 07:00 PM   #6
littlegreenmonstor's Avatar
have you looked for a vacum leak with starter fluid you spray them intake where the head meets and if you notice it pick up than it's intake manifold leak
littlegreenmonstor is offline   Reply With Quote
Old 05-14-2009, 01:10 PM   #7
In time-out for misbehaving.
An easy way to pressurize the intercooler piping is go buy a PVC hose end that is the same size as your intercooler, drill a hole in the center and install a valve stem. All of this should cost you a few bucks. Then unhook the turbo and place the PVC hose end in the coupler and tighten the hose clamps. Then add pressure using an air compressor or go to the closest gas station and use the tire station. Then listen for leaks. This will only tell you if you have a boost leak, for vacuum you need to test the intake mani side.
teamsprock is offline   Reply With Quote
Old 05-15-2009, 03:38 AM   #8
sweet thanks teamsprock! i will try that this weekend, and will keep you guys updated!!
SEO by vBSEO 3.3.0
