Old 05-11-2009, 06:52 PM   #1
270R's Avatar
SR Boost gauge
hey i have a 97 black top in a s14...
I just installed my boost gauge (autometer mechanical) its pretty cool. but im wondering if my meter should be in a vaccum at idle? cuz its at zero ..
should'nt it be at a vaccum at idle? or is it like that cuz its turbo?
thanks ..
270R is offline   Reply With Quote
Old 05-11-2009, 08:17 PM   #2
SHOW SUPPORT, DAMNIT!
Pacman's Avatar
Send a message via MSN to Pacman Send a message via Yahoo to Pacman
Check for leaks at the gauge. Vacuum should exist at idle.
Originally Posted by shinhed View Post
Lets leave exaggerated side skirts and rainbow flakes in the past.
Pacman is offline   Reply With Quote
Old 05-11-2009, 08:31 PM   #3
yes it should be at vacuum @ idle. do what pacman says. check for leaks.
midnight_rex is offline   Reply With Quote
Old 05-12-2009, 02:43 PM   #4
s13
Check the way you hooked up your vacum lines, had the same problem before.
s13_sr20det is offline   Reply With Quote
Old 05-12-2009, 02:51 PM   #5
It has to connect to a pot on top of the TB.
greenman100 is offline   Reply With Quote
Old 05-12-2009, 03:06 PM   #6
Banned from the Marketplace
yes you need vac at idle..
check fsm and it should tell you what the readings need to be.
dondochaka is offline   Reply With Quote
Old 05-14-2009, 08:44 PM   #7
270R's Avatar
well I fixed it... Turns out I could only get pressure out of that port from the TB, So I teed into my waste gate now it works perfectly. damn autometer kick a**
btw does anyone know what those other ports r for? when I first got the engine they were both blocked off by a rubber cap....
SEO by vBSEO 3.3.0
