Old 05-10-2009, 02:17 AM   #1
Does anyone know what this relay is ?
I crossed my battery cables, and as a result I toasted all my fuses. I replaced all my fuses, but now I don't get any spark from the ignition coil.
Can this be the problem ? if so what is it called ?
This is a zoomed out view I know it's a relay but which relay specifically ?
I really think this could be the source of the problem since all my fuses work.
Why does the sig have so many rules
opticnerv is offline   Reply With Quote
Old 05-10-2009, 04:22 AM   #2
condensor/resistor. the fsm has some specs to test.
surreybc is offline   Reply With Quote
Old 05-10-2009, 09:31 PM   #3
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
No spark after crossing your battery cables...most of the time you either fry the ECU or the igniter chip.
fliprayzin240sx is online now   Reply With Quote
Old 05-10-2009, 11:57 PM   #4
I tried a spare ignition coil that came attached to a wiring harness I bought back in the day and that one didn't work too. What are the chances they are both beat ?? Also an igniter chip is the connecter piece on the ignition coil right ?
Old 05-11-2009, 05:20 PM   #5
from the looks of it you have dohc ka you wouldnt have an ignitor chip you have a coil. the fsm has instruction on how to test that part look it up
toointoxicated62 is offline   Reply With Quote
Old 05-11-2009, 09:08 PM   #6
the ignitor chip is visible in picture. the plug plugs into it.
Old 05-14-2009, 05:37 PM   #7
I found the problem !! It was the crank angle sensor the connector got loose !!
SEO by vBSEO 3.3.0
