| | #1 |
| Leaky Injector ![]() | Hey guys, I’ve been trying to knock out an issue with a 91 240 w/ SR20 that I just picked up and I just can't seem to get it right. The previous owner did a shit job with the engine not only with maintenance, but with install as well. Here’s what I’m looking at… ![]() ![]() ![]() ![]() As you can see, it looks like ass. The car is running on stock injectors, stock MAF, supposedly has a Walbro fuel pump, FPR, and a huge top mount T3/T4 w/ external wastegate. What’s happening right now is that it’s not boosting or even running right over 3500. Right now the vacuum is from the top and bottom of the wastegate to a T which then goes to one of the ports on the intake manifold (other port is to the FPR). Is this correct? I’m not trying to do heavy boost, I just want to get it at least functioning before I tear it apart to rebuild it. For the record though, I’ve got 740cc injectors, rom tuned ECU, and a z32 MAF waiting to be put on once things get ironed out.
__________________ 1990 240sx: Bone stock Last edited by Otherworldview; 05-08-2009 at 08:47 PM. |
| Sponsored Links | |
| | #2 |
| Nissanaholic! ![]() | damn that some ghetto piping, check MAF, and turbo for shaft play you really need install those injectors, ECU and MAF If you still have the Stock Fuel electrontics, check your ECU for Codes
__________________ 1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress |
| | #3 | |
| Leaky Injector ![]() | Quote:
I would think though that those would be considered power adders for higher boost? I'm just trying to get the thing to at least boost stock so I know it's set up right.
__________________ 1990 240sx: Bone stock | |
| | #5 | |
| Nissanaholic! ![]() | Quote:
Get a turbo blanket and replace that thing. Def not safe at all
__________________ 1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress | |
| | #6 |
| Leaky Injector ![]() | Yeah, the whole thing is beat. That cylinder being half melted (still functional though), and a Gatorade bottle for a coolant overflow. This is going to sound bad on my part, but these are things I'm not too concerned with because I'm going to be selling the rolling chassy once I pull the engine. I just bought the car for the engine and the parts it came with.
| | #7 |
| Leaky Injector ![]() | Alright, found this vacuum setup on NICO, but it still didn't help any: ![]() Is it because I don't have an actual controller on it that it's not working or am I missing something else? Thanks
| | #8 |
| Leaky Injector ![]() | Alright, trying to wire in the z32 MAF I got and the color for the wiring doesn't seem to match the guides I've found online. I have two sets of wires: one set is a black with a silver ring on it and a thicker white. The other set is a black and another white (but smaller gauge then the other). The second set is in it's own wrapping that's shielded from the other set. Could I get a hand real quick so when I get back from work I can solder this up? Thanks
| | #9 |
| Nissanaholic! ![]() | Not sure if if your Z32 MAF is the same as Mine, I've seen a few different style's depending on the Car you took the MAF off of. Very simple I think I took mine off of a J30 But the wires seem to matchZ32 Plug SR Wires Black w/ White stripe = Black with w/ Whit stripe White = White Solid Black and and Solid Orange = Black Double check you wires before starting with a Mulitmeter because if wired wrong you will fry the ECU. White wire should have 0-5 Volts (B) Orange and Black Wire = Grounds (C&D) Black w/ White Stripe = 12 Volts (E) ![]() Dont mind mine, I spliced my Z32 with my Stock SR plug so if my Z32 MAF went out I can up the stock one back on easily ![]()
| | #10 | |
![]() It goes Big white, Black, Black w/ white ring, white
| | #12 |
| Nissanaholic! ![]() | Your plug is upside down Yours appears to be Big White wire = 12 Volt (E) Two Middle Black Wires = Grounds (C&D) Small Whire wire = 0-5 Volts (B) Like I said, before applying power Check the wires with a multimeter
| | #13 |
| Leaky Injector ![]() | First off, big thanks for Sileighty_85. I was able to get the MAF wired in. Now however, I've come into another problem. It's running really rich. I can't accelerate at all without it almost bogging out then backfires when I let off. Here's what I did: z32 MAF NGK BKR7EIX-11 (gapped to .03) 740cc injectors ECU Rom tuned for 740cc injectors, t3/t4 turbo, z32 maf, and 264/264 cams I adjusted the FPR down to 40PSI at idle. In order to get the thing to start, I had to crank the CAS to be fully clockwise. Once it warmed up I was able to drop it down to fully counter clockwise and it idled at about 800rpm. The only thing I could think of is that I'm not running the 264s, but I wouldn't think that would cause it to run that rich. Anything else I could look at? Thanks everyone
| | #14 |
| Nissanaholic! ![]() | Check for Vacuum leaks plugs need to be gapped at .28 -.30 Cams could be an issuse, but make sure that your getting 12 Volts on the (E) Wire
| | #15 |
| Leaky Injector ![]() | Sorry Sileighty_85 I still haven't picked up a multi meter just yet. I'll get to it soon. Did check vacuum on the plenum and looks good. Here's a video of it running. Edit: Just went out with a multimeter and found I'm only getting 1-2 volts at idle on both E & B. I know when I first went to wire it up, the harness was already chopped and had new lines crimped on. Went ahead and cut out the crimps and just twisted them together with some vinyl and still no joy. Following your pictures and write up I came up with: Harness ------------> Plug White --------------> White (B) Black & Black w ring -> Black (C&D) Big White -----------> Black w/ stripe (E) I'll go back out tomorrow and double check the plug gapping. I forgot about that till now. Edit x2: Plugs are gapped to .030. They were all quite carbon fouled from running rich. Cleaned them off with a shop rag before putting them back.
__________________ 1990 240sx: Bone stock Last edited by Otherworldview; 05-16-2009 at 09:46 PM. Reason: updated electrical findings |
| Sponsored Links | |
| | #16 |
| Leaky Injector ![]() | Sprayed down the MAF with MAF cleaner and got a different multimeter. Got up to 30v on E and 2~3v on B. Still studders so I'm guessing it is the lack of cams that are doing it since that's the only variable left?
| | #19 |
| Leaky Injector ![]() | Yeah... don't think the MAF is properly working. I can't rev over 2500 without it really breaking up. Anyone have one I could borrow for 10min? lol Went and double checked my work. Found I had the multi set to vAC not vDC . Got 12v on E and 1v on B with the car just set to 'On'. Still doesn't explain WTH it's problem is.
__________________ 1990 240sx: Bone stock Last edited by Otherworldview; 05-18-2009 at 07:30 PM. |
| | #20 |
| Leaky Injector ![]() | Went out again and pulled codes. Got 11 and 12 for CAS and MAF. For the CAS we pulled the valve cover, put the cams at 10 and 2 and put the CAS in the center of it's adjusting area. Now it won't start and is pulling Code 55.
| | #23 |
| Leaky Injector ![]() | Major update: Pulled valve cover again here's what I've got (9 links between marks): ![]() That's with the crank at the second mark from the left: ![]() Well, pulled the CAS and reset the marks. Slapped it all together and fired it up on the first crank. Great! Got it running again, but still wouldn't go over 3500rpm... Having enough of that I went back and double checked the pin out to find out where the MAF went. Sure enough after going back the line for the MAF was cut. Not just cut, but a good 3" chunk of wire missing. Spliced in a temporary wire and once again fired it up.... Whelp, that did thte trick. She now runs all the way up to 7500rpm. The only problem I can identify right now is at 1500rpm it hesitates and stumbles. Once I get to 2k+ it pulls fine. Unknown boost right now which is my next question; vacuum. I still can't figure out where the compressor fitting goes? Should I "T" it onto the line from the intake to the wastegate? Almost done guys! Getting excited. ![]()
| | #24 |
| Zilvia FREAK! ![]() | you were 180 off on the CAS.. good news.. you need to use shielded wires for the maf. that COULD be your 1500rpm issue, but could very well be a leak too. The wastegate getting its signal from the IM is fine, however you are sacrificing a bit of response (and engine bay cleanliness) by not just tapping your compressor housing. try to use as FEW T's as possible. |
| | #25 | |
Yeah, it looks like a mess, but it's ok, it's temporary till I do the swap and everything.
| | #26 |
| You love to hate me! ![]() | use the IM for gauge and bov, the large vac line in on the manifold near the firewall should go to your brakemaster then the bov. your wastegate should be directly connected to your compressor housing.
__________________ |
| | #27 | |
| Zilvia FREAK! ![]() | Quote:
dont T your brake booster line and bov. bov gets one line (no t) from the larger nipple on the TB. brake booster gets one line (no t) from the bottom rear of the IM. you can T your guage and fpr from the smaller nipple on the TB, and tap the compressor for WG signal. any more and you should be running a vacuum plenum or tapping your IM. | |
| | #28 |
| Leaky Injector ![]() | Regression Just got back from leave and I dunno what happened during the 3 days I was gone, but it's back to it's old BS. Went out and changed up my vacuum lines like thus: ![]() Throttle body has only one nipple on it (to charcoal canister correct?) and that's currently capped off. The other two on the IM go to the FPR and BOV. Currently don't have a boost gauge or controller, but mocked them up anyways. Get in the car, start it up and it idles at 1500, figure it's alright, it's just warming up. Let it warm up a little and pull off. The whole thing just bucks like crazy through all RPMs. If I'm about 1500 with with little throttle it's alright, but if I give it any more it just starts choking again. Gimped it back to my parking spot and checked the codes. Gave me 55. I tear back into the wiring harness and double check to make sure the MAF wiring we did last Wednesday still held and it was there. Figured maybe it was the plugs; so pulled them and all were dry fouled (running rich?). I haven't gone back to start it up after wiping down the plugs with a shop towel because I don't think that's exactly what the problem is. Edit: Pulled the coolant temp sensor because I read it will cause the car to run rich. I think it's in pretty condition: ![]() Another thing I was considering were the o-rings on the injectors. They looked good and I put some of the grease deatschwerks gave me, but I'm considering anything really at this point. Would it also be because I'm using a red top 62 ECU cause issues? It has a topsecret daughter board.
__________________ 1990 240sx: Bone stock Last edited by Otherworldview; 05-24-2009 at 04:33 PM. |
| | #29 |
| Leaky Injector ![]() | Curious if leaking coolant would also cause it to run bad? I know the U shaped hose on the back of the block near the turbo/brake cylinder hisses every time I turn the car off from running after a while.
| | #30 |
| Nissanaholic! ![]() | you need to check the resistance on the coolant temp sensor (read FSM) not the physical appearance of it. the leak will cause aiir bubbles in the system eventually, so you need to fix it before it starts to over heats is the Daughter board you are using set up for use with the deatscherks? every brand injector has a different lag time.
| Sponsored Links | |
| Bookmarks |
| Tags |
| boost, sr20det |
| Thread Tools | |
| Display Modes | |
