Old 05-08-2009, 04:50 AM   #1
miklos's Avatar
Oil catch can location & replacement KA24E
Is the hose going from the PCV down the center of the engine going to the Oil Catch Can? How can I get in there to see it & change it?
miklos is offline   Reply With Quote
Old 05-11-2009, 05:30 PM   #2
ka24e doesnt have a oil catch can stock?
to replace a pcv valve its below the manifold behind the alternator. you have to take the alternator off to access it.
toointoxicated62 is offline   Reply With Quote
Old 05-11-2009, 06:02 PM   #3
KingKong8247's Avatar
Send a message via AIM to KingKong8247
PCV valve on a single cam KA is right on top of the intake, very easy access. The dual cam's is under the alternator and hard to reach.
And the hose goes down through the middle of the runners to a breather thingy on the left side (facing the front of car) of the timing chain cover.
Just happened to have some pictures:
PCV valve
Side of timing cover
That hose is coming from the PCV valve.
90 240sx Coupe
KingKong8247 is offline   Reply With Quote
Old 05-11-2009, 07:20 PM   #4
miklos's Avatar
There is also a small hose running from the ECCS downward right by the PCV hose. Where does it go?
And is it possible to replace these while the engine is together in the car?
Old 05-11-2009, 07:40 PM   #5
Its possible to replace these but a big PITA.
The small hose is a coolant hose that goes to a tube under the IM.
90 240sx Coupe
Old 05-11-2009, 08:03 PM   #6
miklos's Avatar
If that hose or the PCV hose develops a hole--would it be a minor vacuum leak?
Old 05-12-2009, 12:18 AM   #7
The PCV hose will cause a vacuum leak but the small hose would have coolant leaking.
90 240sx Coupe
SEO by vBSEO 3.3.0
