Old 05-06-2009, 08:13 AM   #1
t15
t15's Avatar
Send a message via Yahoo to t15
SR 2871R bell like ringing?
I dropped in a 2871R on my SR and its spooling up just fine, but im getting a bell like ringing from the turbine, the 2871 was brand new and i can hear the ringing thru the intake. Im assuming its the bearings but i dont know if thats bad or not, never heard of this problem before, any ideas?
Thanks,
Tee
t15 is offline   Reply With Quote
Old 05-06-2009, 08:21 AM   #2
AFC #1
S14DB's Avatar
Is it ringing all the time or only at certain times(stop,start,idle,rev..)
What is your intake and intercooler piping setup?
Comments should be taken as Opinions not as Statements of Fact.
Old 05-06-2009, 08:24 AM   #3
t15
t15's Avatar
It rings while boosting but its in and out and same when i start it up, itll ring for a second or two maybe 3 and then stop wait a few and then start ringing again. I have a FMIC and a HKS intake
Old 05-06-2009, 08:41 AM   #4
AFC #1
S14DB's Avatar
Like a whine,hum,tone or ding, ding, ding?
Old 05-06-2009, 08:44 AM   #5
t15
t15's Avatar
Its a bell like if you got a little cat bell or something like that, so ding, ding, ding would probably best suit it.
Old 05-06-2009, 09:39 AM   #6
slider2828's Avatar
Wow, is it loud? I get some ball bearing spool down noise, but I never hear it during idle or boost.... What company is your turbo from?
Turn and Burn!
Old 05-06-2009, 10:30 AM   #7
t15
t15's Avatar
Its from Garret, ive been told that its just cause its new but im not 100% sure on it thats why im asking if anyone else has heard about this before
Old 05-06-2009, 12:06 PM   #8
t15
t15's Avatar
anybody know something i dont?
Old 05-06-2009, 12:14 PM   #9
deukalionS14's Avatar
i have the same turbo and i dont get that sound at all. was there any shaft play? you should check that 1st and that should give you a better id3ea of what it may be.
want to be in the 500whp club by the end of next year!!!
deukalionS14 is offline   Reply With Quote
Old 05-06-2009, 12:29 PM   #10
t15
t15's Avatar
no there was no shaft play
Old 05-06-2009, 12:41 PM   #11
army240's Avatar
Does this turbo have an internal wastegate??? I've seen one time a broken spring in the actuator... or one time, my friend had a hks adjustable actuator, and it was so tight that the spring inside the actuator was loose, and ding ding it goes...
army240 is offline   Reply With Quote
Old 05-06-2009, 12:43 PM   #12
FusionR240sx's Avatar
Send a message via AIM to FusionR240sx
never had that problem either.
just hearing the bearings spin around when u shut the car off for a few seconds.
FusionR240sx is offline   Reply With Quote
Old 05-06-2009, 12:49 PM   #13
t15
t15's Avatar
yeah i have a HKS actuator, maybe thats it
Old 05-06-2009, 01:21 PM   #14
army240's Avatar
It does the exact same sound, like your bearings would be busted.
Old 05-06-2009, 01:36 PM   #15
t15
t15's Avatar
Ill check it out, thanks to everyone for all your inputs!
Old 05-06-2009, 02:18 PM   #16
hope you find out whats going on!
Old 05-06-2009, 02:32 PM   #17
shifts13's Avatar
sounds like your hks actuator is at the lowest setting causing the wastegate to flap back and forth. put a bit more load on the actuator and you should be fine. same shit happened to me.
shifts13 is online now   Reply With Quote
Old 05-06-2009, 03:15 PM   #18
t15
t15's Avatar
anything else you think i should do? how big of a load did you put on it to make work correctly?
Old 05-06-2009, 04:04 PM   #19
My 2871r makes this exact same sound, but only at idle. It sounds like it could be bearing noise, but the noise does sound kinda like a bell. I can really hear it good at my air filter while the car idles. My 2871r has about 3000 miles on it boosted at 16-18 psi.
I havent noticed any ill effects associated with the sound though.
S13NismoStyle is offline   Reply With Quote
Old 05-06-2009, 04:32 PM   #20
t15
t15's Avatar
So is this something that could potentially hurt me?
Old 05-07-2009, 01:56 PM   #21
shifts13's Avatar
just enough so that the wastegate doesnt rattle.
Old 05-07-2009, 04:13 PM   #22
4x4le's Avatar
Send a message via AIM to 4x4le Send a message via Yahoo to 4x4le
Holy crap! I have been searching and searching for that freaken bell noise forever! I have been under it and on top of the engine bay looking everywhere trying to see what is loose and making that noise! Its kinda irratating! It seemed to me that engine rattle was when it was most present so I thought something was loose. It seems to do it most when its cold. I never thought it would be the turbo. I have my actuator turned down quite a bit so Im going to look into that too.
NEW/CHEAP s13/14sr CAS
Authorized NIStune Dealer
4x4le is offline   Reply With Quote
Old 05-07-2009, 04:51 PM   #23
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
You are running a oil restrictor right? Too much oil pressure will fry those bearings in less than a year...ask me how I know...
SEO by vBSEO 3.3.0
