Old 04-18-2009, 09:26 PM   #1
s14 Help fresh SR swap. clutch? tranny? flywheel? wtf?
Hey everybody!! this is my first post on Zilvia fourms, wish i came here before when i didn't have car issues. but cant ask for everything eh =/
My issue.
well, it all started on easter, having a lil bit of fun, driving the sr20 harder then normal, etc.. swap just got completed about 2 weeks ago, no problems.. then it started.. when i wold shift gears, the rpm's would freelance they're way magically to higher * unnecessary high* rpm, 5-6-7, even when shifting at 2-3500k as if slippage was occurring. the car had a swap done by my friend who has done 10+ SR,RB series. it was an automatic 95se 240sx.. converted to SR20DET redtop manual 5pd the donor car was my friends JDM KPS13. anyways, back to the slippage, what ended up happening, was it started to do it more and more, the clutch when stopping+going in traffic would almost seem as if all the clutch work while driving was *almost* happening automatic, if i put my foot down ease up on clutch and give gas to go, however what was happening is i could depress clutch, release quickly while giving gas and it would not stall etc it would take off fine, as if the clutch was working by it self SORT-OF. so a few hours went by, i get in to drive and all of a sudden what happens is, im about to take off, i depress clutch, feels nice and springy like it should then, i get ready to take off, then the car doesent move at all, rpms to thru 1-2-3-4-5 and im not moving anywhere i should be moving by this time. car will not move, in any gear, also when i get into a gear and let go of the clutch the car does not die. even though it was previously automatic and i dont need to push clutch in to start car. the car should definitely die when i let go of the clutch with no gas in gear. reverse worked longer then gears 1-5th; but soon stopped working as i backed it into my friends driveway for the night..same issue. car wont move when in gear, rpms just scale up and car will SLIGHTLY move itself maybe 2-3 inches when i should be fully moving at normal speed!. also. clutch pedal is still springy. once again the car is a auto to sr 5 speed conversion. thanks.
lets see some feedback.
thanks alot,
~iammikeol
clutch? flywheel? transmission?
iammikeol is offline   Reply With Quote
Old 04-18-2009, 09:46 PM   #2
Sileighty_85's Avatar
Replace the clutch
Pedal stiffness has nothing to do with your clutch life
後輪駆動車1番
1991 Built SR GT2871R -363whp 1998 S14 W/RB25- Rebuild in Progress
Sileighty_85 is online now   Reply With Quote
Old 04-18-2009, 11:23 PM   #3
SR coo
thanks, i had a few people come take a look at it, they said the same thing.
i got another problem.. its a double whammy.
so, the sr20 was overheating, now... its a 240sx 95 SE with a automatic KA, to manual SR swap. so what we did was take out the thermostat, it made a little difference, but still, temp goes up wen i smash out and hit boost?
i have oem radiator, with oem cap and oem shroud. still overheat. thot it was headgasket,(OILS fine, i do have a valvecover gasket leak though, radiator fluid is up to level, no bubbles in overflow rad..) but took it to a shop they tested it. and said it was the clutch fan. infact he stuck his hand in there wile on idle.. would that be the problem, or are they just not all that strong fans when on idle..? the man suggested E-Fans, but why would a all stock oem'd out sr20det overheat??
Old 04-18-2009, 11:48 PM   #4
Does your car sound like a UPS truck when it warms up? IF not than your clutch fan is broken.
WTB s13 side skirts.
singlecamslam is offline   Reply With Quote
Old 04-19-2009, 12:03 AM   #5
Question ?
maybe you could rephrase that for me? because my car never sounds like a ups truck. just a sr20det...and he says he runs hot.
Old 04-19-2009, 12:14 AM   #6
How hot is hot? Do you have a aftermarket gauge? How do you know that its running hot and not a faulty gauge or air in the system.
Old 04-19-2009, 12:26 AM   #7
Question k
i dont know, i been looking for a friend with the laser temp tool so i can drive hard look up the normal op temps and compare.
is taking out the thermostat harmful to the motor at all?
im using a SE 240sx cluster, with stock temp hooked up to a redtop sr20det custom harness..
not sure if its reading correctly..
but, TEMP wont go up on idle, or when car is driven at night softly...
hotter days = hot temp.
my friend, the one tat did the swap said its a close reading but still incorrect..
anymore suggestions?
i dont want to risk overheat, warp block. etc.
thanks.
Old 04-19-2009, 10:40 AM   #8
Nissanaholic
reflexdb's Avatar
Send a message via AIM to reflexdb
Isn't the S13 SR20 water temperature sensor not compatible with the s14 cluster? I thought that the output characteristics are different than the S14 SR20 sensor, and when the S13 sensor is used with an s14 cluster, the gauge reads high temperature when the water temperature is OK.
Garage-ridden S14. Driveable?...maybe someday.
reflexdb is offline   Reply With Quote
Old 04-19-2009, 10:59 AM   #9
Yes the temp sensor has to be matched up with the cluster you're using.
Old 04-19-2009, 11:43 AM   #10
intresting. now where getting somewhere.
redtop in an s14 would cause that issue. but its strange how the temp reads, almost as if it is accurate because temp will only incline when stepping on it hard and hitting/keeping full boost.
you think it would be dangerous to just forget about the temp reading issue..
motor does seem hot to touch, but not *to hot to touch*
etc...
what would be the case of my weak clutch fan, (tech being able to shove his hand into moving clutch fan at idle and stop movement) that was his excuse for saying it is weak and not cutting on the cooling..
Old 04-19-2009, 11:46 AM   #11
Zilvia
You have gave good advice so far guys, thanks alot. most fourms i join everybodys on the quest for I-Know-Everything-And-Wont-Give-Advice attitude. im going to get the clutch problem fixed and ill see what happens..
Thanks
~michael
Old 05-19-2009, 03:50 PM   #12
Clutch fixed
got fidanza carbon kevlar clutch kit from phase2mototrend.
good price. works good. service at P2M is GREAT.
thanks.
if anybody was wondering/OVERALL LESSON LEARNED for beginners.
CLUTCH IS NUKED IF YOU CAN RELEASE CLUTCH IN A GEAR AND CAR STAYS ON..
Old 05-19-2009, 03:56 PM   #13
Removing the thermostat can cause an engine to overheat....
RHD95S14 is offline   Reply With Quote
SEO by vBSEO 3.3.0
