| | #1 |
| I am rebuilding my RB20det from my skyline and putting it in a 240sx when i get to the states. im just curious what everyones oppinions are on what the best headgasket and timing belt to use are. I know i want to go 1.2mm on the headgasket. Thanks | |
| Sponsored Links | |
| | #2 |
| Leaky Injector ![]() | im in the middle of doing the same thing. best head gasket i donno . i might be going with cometic but im still undecided . if you want the best head gasket then go with tomei . but make sure you take your block and head to the machine shop to get plained as for timing belt im going with a greddy belt .
__________________ Rob W. 1992 240sx |
| | #6 |
| I see, im probably planning on running 1 bar to 1.2 bar, i think the head and block should be fine. seeing as i pulled it out of my old skyline that had 105k Klicks, which is like 65,000 miles. I also have 256 tomei cams going in it. | |
| | #7 |
| Zilvia Member ![]() | If your not going more than 500hp the best HG is stock. It can handle the HP and won't leak. The RB cometic has been known to leak even when the block is deck and the head milled.
__________________ rbforums.org RB oem parts/wiring diagrams /fsm's |
| | #9 |
| Hmm, im not a huge fan of oem, unless u can convince me otherwise. i dunno. i was thinking more towards either a tomei headgasket and timeing belt or a greddy headgasket and timing belt. I'm just more in the mentality of hey ya know im already here, heads off. Have the of money, Why not? Last edited by RBD240; 02-06-2009 at 04:26 PM. | |
| | #10 |
| im a lion ROAR im a dinosaur ![]() | if you have the money, go for it i guess. but like i said, theres not really a point. personally i wouldnt want to have to redo a head gasket from buying a shitty gasket. but its your car, time and money. sounds like you already had your mind made up before you started the thread |
| | #13 |
| Yes For sure! Head and exhaust studs, Headgasket timing belt head studs Tomei 256 cams (i have) cam Pullys injectors fuel pump (i have BNR32) Clutch I want to do intake manifold and fuel rail. but im having trouble finding a good quality intake manifold for a good price. | |
| | #14 |
| Zilvia Member ![]() | How much power are you looking for? Not many good options for the RB20 intake manifold. You can try making an adapter to accept the RB26 itb's.
| | #17 |
| Zilvia Member ![]() | You really don't even need to touch the head for your desired HP. I've had Tomei and GREX HG's and they were both a pain to seal right. I had to TQ the arp stud nuts to 85ft lbs for them to seal. I have an OEM gasket on my RB25 now and it's held fine up to 22psi with a 62-1. Also a 1.2mm HG is going to lower your compression on an already low 8.5:1 RB20.
| | #19 |
| Reason for the headgasket is cause the head is already off, im shipping it back from japan in pieces. =) so im just looking to upgrade while its already apart. Thats why i bought tomei 256 cams for it. 1.2mm will lower compression. but a bigger turbo or new compressor wheel should fix that. Like he said im sure i can find torque specs from the maker somewhere. Hmm...i dunno ![]() | |
| | #20 |
| Zilvia Member ![]() | Nah, you should be TQ'ing the head to the mfr specs of the studs/bolts, not to a gasket spec. Either way just make sure the head and block is super flat, super clean and use copper spray on the HG.
| | #22 |
| im a lion ROAR im a dinosaur ![]() | i dont think so. even if you could i wouldnt recommend it. normally you only want to use a head gasket once, once u unbolt the head the pressure is off the hg and might not seal up again |
| Bookmarks |
| Tags |
| rb20det |
| Thread Tools | |
| Display Modes | |
