Old 01-08-2009, 10:17 AM   #1
vladimir240's Avatar
Send a message via MSN to vladimir240
compression test...
hey guys. im currently blowing a crap ton of white/blue smoke on deccel. i had th turbo off the other day and there was some shaft play in and out, but not up and down. did the compression test last night(and wow starter is about to go out) and here are the results.
1 cyl- 145 psi
2 cyl- 140 psi
3 cyl- 140 psi
4 cyl- 145 psi
i tried reading googling around and got that numbers are supposed to be around 160?? so if you'all could tell me weather my numbers up there mean that i have bad rings?? or just a bad test?
any help will be appreciated. thanks
vladimir240 is offline   Reply With Quote
Old 01-08-2009, 10:23 AM   #2
Sileighty_85's Avatar
Thats not too bad
A brand new SR according to the FSM is 157psi
Adverage is about 150
I got a friend whos is around 130-135 still runs and pulls hard
More than likely is the turbos oil seals are shot
Im sure if you pull the turbo off and check the exhaust side it would be oily.
How does the Compressor side look? Clean or oily?
後輪駆動車1番
1991 Built SR GT2871R -363whp on Stock Cams/IM
Old 01-08-2009, 09:58 PM   #3
thanks man, oil is all in the piping, even some that just barely come out by the blow off valve. how about shaft play with it going in and out considerbly more, alot, way more, then up and down
Old 01-09-2009, 12:45 AM   #4
that turbo's toast, time for a rebuild or perhaps an upgrade?
Be sure to clean all that oil out of th IC system too
後輪駆動車1番
Old 01-09-2009, 04:06 AM   #5
[JEFE S14]
GSXRJJordan's Avatar
Send a message via AIM to GSXRJJordan Send a message via MSN to GSXRJJordan
Yup, /thread, it's your turbo. Your motor's not too happy either, but it's aiight. It's not so much the number, as the variance between the cylinders, that'll kill ya - you want <10% variance (you've got much more than that, but that could just be how you measured).
TEAM SUS*PECT is alive.
Nismo drop-in FPR and Nismo FPR Fitting F/S!
www.JordanInnovations.com
GSXRJJordan is online now   Reply With Quote
Old 01-09-2009, 07:16 AM   #6
SLINKY + ESCULATOR = Fun Times
fliprayzin240sx's Avatar
Some up and down is acceptable, lots of in and out is bad. Thats how you know the bearings are done and with the oil in your compressor side, seals are done too.
Old 01-09-2009, 11:41 AM   #7
yea Sileighty a upgrade would be nice, but not in the budged right now...
thanks for all the replys guys
Old 01-10-2009, 08:03 PM   #8
handinpants's Avatar
Trader Rating: (18)
Send a message via AIM to handinpants
"My Penis is so big that if I laid it out on a keyboard, it would go from A to Z!!"
Hah! A and z are really close to eachother
handinpants is offline   Reply With Quote
Old 01-10-2009, 08:23 PM   #9
Trader Rating: (18)
Old 01-11-2009, 12:18 PM   #10
..........wtf?
Old 01-11-2009, 12:39 PM   #11
Originally Posted by vladimir240 View Post
..........wtf?
hes talking about fliprayzin's Sig
後輪駆動車1番
SEO by vBSEO 3.3.0
