Zilvia.net Forums
Go Back   Zilvia.net Forums > General > Tech Talk > Engine Tech
Old 08-28-2008, 08:45 PM   #1 (permalink)
project-D180's Avatar
heelp !!!
jus got finishin rebuilding my kade a few days ago..just got it 2 start and run but it doesnt seem like it gettiin oil pressure..how do i check it other than takin the front cover off again"??this really sucks cuz it sounds soooo mean runnin.. but it ran for a lil and shut right off like it had a vac leak or no maf..heeeeeeeeeeeeeeeeeeeeeeelllllllllllllllpppppp pppp!!!!!!!!
project-D180 is offline   Reply With Quote
Old 08-29-2008, 05:12 PM   #2 (permalink)
tps sensor??????
drftthatshit is offline   Reply With Quote
Old 08-29-2008, 05:14 PM   #3 (permalink)
Swapping my rb...
MELLO*SOS's Avatar
do you have an oil pressure gauge? What makes you suspect the oil pressure?
To start with, Pull the codes from the ECU. Then go inspect all your wiring/connections, vac hoses and base timing. Start with the easy/simple stuff... Then post more symptoms
*** Visit My New Blog: LS400.wordpress.com ***
MELLO*SOS is offline   Reply With Quote
Old 08-29-2008, 05:16 PM   #4 (permalink)
^^^^agree but he rebuilt the moter and 98% of the time it is either the tps sensor or the idle screw that makes the car keep dying
SEO by vBSEO 3.2.0
