Zilvia.net Forums
Go Back   Zilvia.net Forums > General > Tech Talk > Engine Tech
Old 08-17-2008, 08:27 PM   #1 (permalink)
djcobra's Avatar
SR S13 Cam Gear Bolt on S14 Cams
Hi,
hopefully I can get a solid answer from you guys...
I'm having that notorious VTC sound when you rev between 1000-2000rpm; and when I unplug the VTC solenoid the rattle goes away. Anyways, I know that fixing this solution is by replacing the VTC Sprocket which costs around $600 and I rather not go that route, but instead maybe installing adjustable cam gears. Please see my setup as listed below:
S14 Kouki Black Top SR20DET
GT28RS
HKS Step 2 Cams 256in/264ex
HKS Step 2 Valve Springs
Peak Performance Retainers
Apex'i Metal Headgasket 1.1mm
Now my question is can I install a S13 Cam bolt sprocket on my current S14 HKS cams which were designed for NVCS (with VTC) and/or should I install adjustable cam gears which allows me to retard or advance the timing?
I've been getting mixed reviews from people some say you have use the S13 intake cams and some say you can just bolt on the S13 Bolt Sprocket with the S14 Cams. hopefully you guys can give me a straight answer, thanks.
Steve.
djcobra is offline   Reply With Quote
Remove these ads by purchasing a Premium Membership with Zilvia.net!
Old 08-17-2008, 09:18 PM   #2 (permalink)
Shut Yo Muthafucking Mouth!!!
fliprayzin240sx's Avatar
Im pretty sure you just swap sprockets.
My Penis is so big that if I laid it out on a keyboard, it would go from A to Z!!!
*look down on keyboard*
Old 08-18-2008, 05:12 PM   #3 (permalink)
yeah you can go either way you can swap the sprokets or go with the ones thats you can adv. or retard the timming its really your call
drftthatshit is offline   Reply With Quote
SEO by vBSEO 3.2.0
