| | #1 (permalink) |
| help with my POS sr20! (vids & pics) well i got my motor in (s13 redtop sr20) but still running into some problems. i have a nipple on the intake manifold side that i cant figure out where it goes? any one have a clue, heres a pic: ![]() and i checked over my entire wiring harness (ka harness) and i cant find a clip or anything for this. can i run without it or is it important: ![]() and last but not least when i had everything in except for that hose and the ground clip, this is what my car would do. it wouldnt turn over or anything, the clock would just lose it's light and that all. ![]() | |
| Sponsored Links | |
| Remove these ads by purchasing a Premium Membership with Zilvia.net! | |
| | #6 (permalink) |
| Premium Member ![]() | does the starter click at all when you turn the key? if it doesnt, you might not have it wired right. if it does, your batt might have enough juice or the solenoid is dead. when i first did my swap, the starter would just click. i swapped the solenoid from an extra starter i had and it fired right up. |
| | #12 (permalink) |
| Zilvia Member ![]() | the one sensor on the left the yellow one is the temp sensor to the ecu it tells the computer to run rich or lean depending on coolant temp the other smaller one is for the cluster in side the car it is only a one wire and should be black dont quote me on that but i belive that it is black as for you starting from watching the vid whay dont you mount the battery down and check all your connections relays fuses also check voltage at the battery and the starter hope this all helps let me no |
| | #15 (permalink) |
| im on the west side of town, all the help would be great, i'm gonna go out to the garage for alil bit and hook the stuff up, also theres another problem i forgot about: my clutch is very very very soft, and it;s a brand new ACT 6-puck clutch kit. i took the dampen box out and bled the clutch line but still weak, possibly the master cylinder? | |
| Sponsored Links | |
| | #21 (permalink) | |
| Leaky Injector ![]() | Quote:
__________________ 1993 AW Mazda RX-7 1997 Nissan Silvia | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
