| | #1 (permalink) |
| Changing headgasket, deck the block? Deck the head? Throwing in a Apexi 1.1mm headgasket 86mm in a stock bore redtop with arp headstuds. DO i need to deck the block? Deck the head? Searched with no luck, thanks in advance! | |
| Sponsored Links | |
| Remove these ads by purchasing a Premium Membership with Zilvia.net! | |
| | #3 (permalink) | |
| op uɐɔ ı ʇɐɥʍ ʞooן 'ʎǝɥ ![]() Join Date: Sep 2002 Location: deleting election shit from my email Age: 29
Trader Rating: (3) | Hell, with the hardware and money you're putting into it, do it even if it DIDN'T overheat.
__________________ Quote:
![]() Bought something from me? Talk about it. "Ask PHLIP a question, ask me anything" | |
| | #4 (permalink) |
| i assume you can deck a block with all the internals still inside it? same with a head? my engine's overheated atleast once while i've owned it and i plan to do the gasket and all other bits when i do my cams. what other work should not be overlooked while you have everything apart???
__________________ -S14 Silvia K's | |
| | #6 (permalink) |
| Premium Member ![]() | You can check the head yourself if you know how to use a feeler gauge. It should be in the FSM, basically you put a true flat level on the heads surface, then you feel the gaps with the feeler gauge, it should be within a certain spec. If not, then you need to get it decked. |
| | #7 (permalink) |
| KA-T > SR ![]() | yes you should regardless, your using a flat metal gasket now, and it'd really be in your best interest to just go a head and deck them so you have a smooth, flat surface for it to seal on. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
