Zilvia.net Forums
Go Back   Zilvia.net Forums > General > Tech Talk > Engine Tech
Old 08-15-2008, 09:48 AM   #1 (permalink)
Firestorm's Avatar
Send a message via ICQ to Firestorm
CA bogging and rough idle
good morning america,
a friend of mine has an issue with his CA18DET. it idles really rough and bogs on throttle. we checked for vac leaks and found nothing yet.
usually when you pull the vac line going from the wastegate to the intake manifold it should rev up on idle (we tested that on a friends CA) but when whe pull it on his it just dies.
we're going to replace the MAF and see if it gets better but the vac issue is puzzling me.
thanks in advance.
Firestorm is offline   Reply With Quote
Remove these ads by purchasing a Premium Membership with Zilvia.net!
Old 08-15-2008, 10:56 AM   #2 (permalink)
TTrx7Pete's Avatar
How are you checking for vacuum leaks? I've found that some of my vacuum leaks would not show up until I had a constant 20psi of pressure, pressurizing my system.
1993 AW Mazda RX-7
1997 Nissan Silvia
TTrx7Pete is offline   Reply With Quote
Old 08-15-2008, 02:08 PM   #3 (permalink)
Firestorm's Avatar
nevermind, we changed the MAF and it runs better now.
SEO by vBSEO 3.2.0
