Zilvia.net Forums
Go Back   Zilvia.net Forums > General > Tech Talk > Engine Tech
Old 08-14-2008, 10:08 PM   #1 (permalink)
jdmnismo's Avatar
s13 Having problem starting my s13
Just the other day i was driving my s13 around and when i got home i noticed that it was overheating so i realesed the pressure. Then 10 minutes later went and added more water. So i went to go crank it and as i did that it turned on and died atomatically it happend around 5 times now it just cranks and cranks. And a few days ago i changed the battery so i dont know what the problem could be.
I changed the spark plugs the distributer cap ant the boot. But didnt help any thing. Any one knows what could be wrong or any suggestions to elimating the problem it would be really help and i would appreciate it a lot. thanks!!!
jdmnismo is offline   Reply With Quote
Remove these ads by purchasing a Premium Membership with Zilvia.net!
Old 08-14-2008, 10:34 PM   #2 (permalink)
Drunken Phan
Sleepy240's Avatar
Send a message via AIM to Sleepy240
You might wanna post a little more info...
Do you have spark? (even though you checked the plugs)
Do you have fuel? (leaky injectors etc?)
Sleepy240 is offline   Reply With Quote
Old 08-15-2008, 05:29 PM   #3 (permalink)
agree^^ i need to know more for all i know you could have a blown fuse or a broken wire somewhere help us and we can help you
drftthatshit is offline   Reply With Quote
Old 08-17-2008, 04:58 PM   #4 (permalink)
jdmnismo's Avatar
how can i check for spark and fuel?
Old 08-18-2008, 05:17 PM   #5 (permalink)
pull the wire off one of the plugs and if you have a spare spark plug lieing around plug it in to the boot you pulled off one of the plugs on the engine and set it on the engine have someone crank the engine over and look for spark. as for the fuel take the fuel line off the fuel rail and make sure you dont pull the return off you will be able to tell then all you have to do is turn the key and watch for fuel to squirt
Old 08-19-2008, 04:36 PM   #6 (permalink)
jdmnismo's Avatar
Fuel pump wasnt turning on when i cranked it over to the second one so decided to take it out was wondering if n e one could give me some helpfull instructions please!!!
Old 08-19-2008, 04:39 PM   #7 (permalink)
jdmnismo's Avatar
Thanks
THanks for ur helpfull advise but i think its the fuel pump cuz its not turning on on the second crank so if u got n e help instructions let me k thanks man appreciate it
Old 08-19-2008, 04:41 PM   #8 (permalink)
Send a message via AIM to s13boy89
be careful taking it out i broke my sending unit
s13boy89 is online now   Reply With Quote
Old 08-19-2008, 11:39 PM   #9 (permalink)
jdmnismo's Avatar
whats the sending unit also their was this house ziptied onto the pump n its not connected 2 n e thing what is it for
Old 08-20-2008, 01:01 AM   #10 (permalink)
pictures!
msglnght
most of you are s
Slammed180 is offline   Reply With Quote
Old 08-20-2008, 11:59 PM   #11 (permalink)
FRoSt415's Avatar
Send a message via AIM to FRoSt415
FYI next time u add water to your car turn it on before you add cold water to a hot aluminum block it can crack or blow your headgasket and have the same problems your having now.check your oil see if its milky if it is blown HG if not probly something else.
FRoSt415 is offline   Reply With Quote
Old 08-21-2008, 01:38 AM   #12 (permalink)
jdmnismo's Avatar
Question but would the fuel pump
if it is a blown gasket would the fuel pump still turn on? cuz when i crank it 2 the second one the fuel pump should be making a noise wich mine isnt! so whats ur suggestion?
proble, starting, wont stay on
SEO by vBSEO 3.2.0
