Zilvia.net Forums
Go Back   Zilvia.net Forums > General > Tech Talk > Engine Tech
Old 08-05-2008, 06:56 PM   #1 (permalink)
draining oil from a ka.
I was just wondering how do i drain the oil from a ka? i think i put a little to much oil in today and need to remove some but im not reallly sure how to. thanks for the help =]
Xcede is offline
Remove these ads by purchasing a Premium Membership with Zilvia.net!
Old 08-05-2008, 07:06 PM   #2 (permalink)
Oh jeez....
You drain oil from the KA just like any other motor.
Jack up the car, put jack stands under it.
Crawl under the car, loosen the drain plug on the oil pan, oil will come flowing out of it.
Make sure you have something to catch the oil in, like a drain pan, and discard of the oil at a local shop.
Reinsert drain plug.
Research before you ask questions
sleepinsilvia23 is offline
Old 08-05-2008, 10:44 PM   #3 (permalink)
Send a message via AIM to s13boy89
yeah what he said just dont loosen it all the way
s13boy89 is offline
Old 08-05-2008, 10:59 PM   #4 (permalink)
Swapping my rb...
MELLO*SOS's Avatar
KA's are very peculiar about draining the oil. Basically, you'll need to drill a 3/8" hole through the oil pan and let it drain for a bit. Afterwards you either have to use a rubber cork/stopper, OR just JB weld the hole shut to prevent oil leaks and bearing failures. This is why most of us just take our car to jiffy lube, it's too much work for the DIY guy to do. Best of luck!
*** Visit My New Blog: LS400.wordpress.com ***
MELLO*SOS is offline
Old 08-05-2008, 11:08 PM   #5 (permalink)
STICK IT INSIDE HER AND PEE
murda-c's Avatar
Send a message via AIM to murda-c
Another way is to start the motor, then remove the oil filter.
That way you use the engine's internal oil pump to push out the oil.
do not do this it will fuck your shit up.
I hear its amazing when the famous purple stuffed worm in flap-jaw space with the tuning fork does a raw blink on Hari Kiri Rock. I need scissors! 61!
murda-c is offline
Old 08-05-2008, 11:13 PM   #6 (permalink)
UNISA JECS's Avatar
I like to remove the oil cap and stick the vacuum hose attachment from my HOOVER vacuum cleaner into the oil fill hole, then start the car and remove oil that way, save times from having to get under the car.
UNISA JECS is online now
Old 08-05-2008, 11:57 PM   #7 (permalink)
Bubbles's Avatar
I personally like to drive over curbs until I look in the rear view and see fluid.
Anything else is too much work.
Bubbles is offline
Old 08-06-2008, 12:06 AM   #8 (permalink)
5t341tH's Avatar
Send a message via AIM to 5t341tH
haha wow this thread is funny. change ur oil much OP?
5t341tH is offline
Old 08-06-2008, 02:40 AM   #9 (permalink)
Send a message via AIM to drifts135
I usually remove the offending engine and the oil goes with it.......
Just kidding, I like KAs, do not come kill me,
drifts135 is offline
Old 08-06-2008, 10:39 AM   #10 (permalink)
i like to pick my car up with my bare hands and flip it over that way i can drain the coolant and the oil at the same time it works so great guys you should all try it some time lol
drftthatshit is offline
Old 08-06-2008, 10:56 AM   #11 (permalink)
Midnight Meat Train
Soup Nazi's Avatar
Who changes their own oil these days?
Pfffffff
91' Sil-Eighty= No Soup For You...
Ever bought anything from me?
Leave a review
http://www.zilvia.net/f/showthread.php?t=200877
Soup Nazi is offline
Old 08-08-2008, 02:47 AM   #12 (permalink)
2_fast_240's Avatar
You guys are all full of shit. Best way is to just remove you oil cap, and start you car.
Still to much oil? Remove valve cover, then start car.
Man, you guys are
'91 240sx hatch: ka-t t3/t04e
'93 240sx coupe: stock dd
2_fast_240 is offline
Old 08-08-2008, 05:38 PM   #13 (permalink)
Send a message via AIM to gijoe69
lol this thread is funny!........if you are new to automotive, best bet is goto a local community college and sign up for a automotive class or goto barnes & nobles/ borders and read automotive maintenance guide lol
gijoe69 is offline
Old 08-08-2008, 06:05 PM   #14 (permalink)
Bigsyke's Avatar
jack up car, locate drain bolt on botton of engine's oil pan. Drain bolt size is an M14x1.25. Make sure you have an M14 copper crush washer from autozone before you crack the drain bolt open. Remove the drain bolt. Make sure you do this cold because you need to quickly put on a new washer, adn you dont want to burn yourself.
Make sure you have at least 1 extra bottle of matching oil. Either match the ammount of oil you have drained, or slowly add oil untill its at the correct MAX line on hte dipstick.
Easier way if you need to remove a little bit of oil, and probably better for the car is to remove the oil filter adn put on a new one. - This you probably want to do whent he engine is hot, because an empty oil filter isnt good.
Bigsyke is offline
Old 08-09-2008, 10:34 AM   #15 (permalink)
She's Thicka Than a Snicka!
EDacIouSX's Avatar
Send a message via AIM to EDacIouSX
you friggin troll
Hospital Records
EDacIouSX is offline
Old 08-09-2008, 10:44 AM   #16 (permalink)
op uɐɔ ı ʇɐɥʍ ʞooן 'ʎǝɥ
PHLIP's Avatar
I am friggin amazed
Originally Posted by Ignignokt
"Getting it is easy... filling it with illegal substances and sending it across the border is not."
Got an issue with me? Discuss it with me here.
Bought something from me? Talk about it.
"Ask PHLIP a question, ask me anything"
PHLIP is offline
dubba you tee eff
SEO by vBSEO 3.2.0
