Zilvia.net Forums
Go Back   Zilvia.net Forums > General > Tech Talk > Engine Tech
Old 08-04-2008, 12:37 PM   #1 (permalink)
Street Specialist
240cracker's Avatar
Fuel Pump Turned off ~ HELP!
Iv had this problem before. Last time it shut off on me i blew a pin on the plug of my Power FC. That isnt the case this time... i checked if the pump itself is getting power, it is. It's a NISMO fuel pump too so its not a stock or cheapy that would normaly go out. I checked all the fuses i could think of that would be even close to related to it. My fuel pressure gauge is showing 0.
Any ideas? shit shut off on me while cruising no high boost or anything.
Thanks
-Steven
240cracker is offline
Remove these ads by purchasing a Premium Membership with Zilvia.net!
Old 08-04-2008, 01:06 PM   #2 (permalink)
1slowS13's Avatar
nismo or not, shit happens. it might've stopped working.
1slowS13 is online now
Old 08-04-2008, 01:21 PM   #3 (permalink)
Street Specialist
240cracker's Avatar
it has power though...
and its pretty new
how would i go about testing it besides testing for power? cuz i did that
Old 08-04-2008, 01:35 PM   #4 (permalink)
In house son of a bitch
projectRDM's Avatar
Remove it, hook it up to a 12V battery.
Done and done.
FORMERLY R240NA
projectRDM is offline
Old 08-04-2008, 01:55 PM   #5 (permalink)
Street Specialist
240cracker's Avatar
Done and done.
i already tested it. hooked it up it worked.
Old 08-04-2008, 01:58 PM   #6 (permalink)
I boycott the word "SWAGGER"
Addicted2Kouki's Avatar
if the fuel pump works then its the ecu, power fc not sending the signal, or your wiring/fuses.
FS:I got KA-T parts and z32 rotors. PM ME!
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS: R33 Skyline-$26K..CA titled and smog exempt.
PM for more details.
Addicted2Kouki is offline
Old 08-04-2008, 02:00 PM   #7 (permalink)
lol pwnt
PBucch's Avatar
Ive got power at the plug, not sure how much, I just have a test light, but the pump is not priming when the key is turned on. I took it out and put it on 12v and it pumped fine.
could it be the relays? all the fuses are good.
section ef&ec changed my life
www.yourshitsweak.net
PBucch is offline
Old 08-04-2008, 03:04 PM   #8 (permalink)
I just had to deal with a similar, if not exact same problem.
Check Relays in fuse box in the engine bay. If their good...
Does your commander turn on when you try to start the car? I tracked mine down to the PowerFC being the problem. (assuming this is s13-s13sr) On your harness there should be an ECCS wire (black/red wire iirc). I think it's pin 5 or so(check your diagram). Strip away a piece of the sheilding so that just the bare wire is exposed. Take a 3' piece of wire, twist it around the ECCS wire, and ground it to your chassis. Does your fuel pump turn on? Commander? If so, your PowerFC isn't doing what it's supposed to do. You can wire in a gound switch from the ECCS, and turn it on before you start your car. Or buy a new PowerFC.
defiantmofo is offline
Old 08-04-2008, 03:05 PM   #9 (permalink)
check the relays then get your self a dmm digital multi meter to see the exact volts going to your fuel pump
drftthatshit is offline
Old 08-04-2008, 03:24 PM   #10 (permalink)
Street Specialist
240cracker's Avatar
its a s14 kouki sr
i think its the same wiring though just the plug itself is different.
i didnt check the relay and a lot of you guys are saying to do that. ill try that first. i hope its not the power fc... eeek
SEO by vBSEO 3.2.0
