| | #1 (permalink) |
| The Kid... ![]() | SR20DET running rich and stutters around 2500rpm. Ok so I have came a loooonnggg way with my swap. It use to bog and stutter really bad around 2500-3000 rpm. So much that the RPMS would not climb at all. It would boost but barely pull. After I reset my timing, the car seems to run much better, but it still bogs a little around 2800prms. Now it pulls great after I get pass the bogging. Also my car is burning A LOT of gas, it runs very rich. I doubt I have have any boost leaks. Anyone have any ideas? Or things I should be looking for? Specs: Redtop Good CAS Set timing Good MAF All coilpacks firing Stock pump and filter Full exhaust and turbo elbow Car idles at 800rpm, doesnt stutter til abount 2800rpm. Stutters for a little bit, then gains rpm and starts to pull. I do have a tuned ECU, I don't know what its tuned for it came with my motorset. I'm going to search for a local SR to borrow the ECU. That could be the problem.
__________________ Nagasaki Motors![]() Friends help you move. Real friends help you move bodies. |
| Sponsored Links | |
| Remove these ads by purchasing a Premium Membership with Zilvia.net! | |
| | #10 (permalink) |
| Shut Yo Muthafucking Mouth!!! ![]() | Start with the usual: Double check timing and boost leaks. If those check out good, then try cleaning the maf. If still doesnt help, try swapping for another known good MAF. Work your way from there...check maf wiring, ECU, etc.
__________________ |
| | #12 (permalink) |
| Leaky Injector | My ecu LED is not there. I have heard that some of them don't have them. I have swapped the MAF(although I guess it is possible that one is bad too), replaced fuel filter, checked tank for rust, check timing and CAS, replaced ECU coolant temp sensor, replaced plugs and checked the gap twice, as far as boost leaks I do have a very slight one (around 1 psi drop every 5-10 secs) that I am having trouble finding. I am considering buying all new couplings and clamps, and eliminating possible places. I have also been told it could be the knock sensor but I need to try all the cheaper things first before buying a 150 dollar sensor. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
