| | #1 |
| Leaky Injector ![]() Join Date: Apr 2008 Location: Grand Junction, CO
Trader Rating: (1) Feedback Score: 1 reviews | strange problem, wont start. i posted something about this a while back but didnt get any answers. ok, i have a sr swapped 240sx (i did not perform the swap) with a few bolt-ons. i did a wiretuck by extending the wires to the injectors, the throttle position sensor, temp sensor (right next to the throttle position sensor plug), the camshaft angle sensor and the radiator temp sensor. ![]() all the arrows point to places i extended wires. i used 16 guage wire and all the connections are soldered and taped. the engine looks a bit messy since ive been taking apart my wiring to check for errors. after my wiring the car started fine but a few days later it wouldnt start when the engine was hot. i had to wait at least 30min to start it after running. then i changed the oil and the oil filter using a greddy air filter and casterol syntec 5w-30 oil. now it wont start at all, it cranks but doesnt turn over. any suggestions, ideas or insight woul help greatly. |
| Sponsored Links | |
| | #2 |
| Nissanaholic! ![]() Join Date: Feb 2007 Location: Memphis Age: 21
Trader Rating: (2) Feedback Score: 2 reviews | Not sure about it not starting, but the warming up then not starting issue is usually due to a loose/disconnected coolant temp sensor.
__________________ Nagasaki Motors![]() Friends help you move. Real friends help you move bodies. |
| | #3 |
Trader Rating: (1) Feedback Score: 1 reviews | someone else told me that, but now that it wont start at all its probably something else. i ahve 2 theorys now, 1 the alarm system could be keeping it from starting (happened to 2 friends) and 2 there could be aproblem with the ecu |
| | #4 |
| Leaky Injector | cts for your warm start issues. You may have dumped too much fuel and flooded the motor which you can just pull the fuel pump fuse and crank a little while and it should start and sputter out of gas if it is flooded. If not, check your cas wiring for continuity all the way back to the ecu. Just get a multi and a pinout and go for it. I also noticed that my car has issues staying alive when the tps is unplugged, so I would do a basic continuity check (sensor grounds as well) on all of the sensors starting with cas and then tps. If you think its your ecu, you may have fried it rewiring this stuff if you shorted anything. if you are down there with the ecu out to check for continuity on the harness, trace the leads from pin 36 and see if its toasted. If not, a brief inspection of all other 12v leads should give you an idea if its ecu related. |
| | #6 |
Trader Rating: (1) Feedback Score: 1 reviews | i pulled the first spark plug out and cranked the engine and there was no spark. am i testing it wrong or are the spark plugs not firing? if the spark plugs aren't firing then what is the problem, i didnt touch any of their wires? |
| | #7 |
Trader Rating: (2) Feedback Score: 2 reviews | Spark plugs maybe fouled, try buy some cheap ones and check it out.
| | #9 |
Trader Rating: (1) Feedback Score: 1 reviews | *nevermind* the ECU gives me 55 - Other Malfunction. CONSULT Terminal Required EDIT: if i buy a USB CONSULT cord with Nissan Data Scan and datalog viewer off ebay would i be able to figure out what the problem is? would this thing be useful for later modifications and stuff? Last edited by .jrmyrmx; 07-12-2008 at 04:27 PM.. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
